Thread: Throttle body
  1. Throttle body
    Feb 2017
    Rochester
    Hi guys
    So took my egr valve off my car today and I noticed the seal around the electrics on the throttle body was poking out the side.
    So I took the case apart that holds the electrics (and mechanism to open the valve up inside the throttle body) and it had a LOT of oil in it.
    Do you recommend changing the whole throttle body?
    Could this cause a vibration?
    Many thanks
    Rob
  2. Re: Throttle body
    135 Post(s)
    2038 Post(s)
    A VERY common problem, the oil gets in there through failure of its spindle seal so yes, you replace it.
  3. Re: Throttle body
    Feb 2017
    Rochester
    Thanks mate. Also the crank pulley I think maybe another cause of the vibration. So I’m going to replace it. I assume I just undo the small bolts and slide it off the centre bolt.
    Is there anything I need to be careful of?
  4. Re: Throttle body
    135 Post(s)
    2038 Post(s)
    err, no!
  5. Re: Throttle body
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    You can clean out the electrics compartment with some brake cleaner or switch cleaner etc.
    If you do, make sure you remove & clean out the electric motor as well & check for any damage on the plastic gears.
    It will of course get more oil in there again.
    But as it is virtually a maintenance item now to clean the accumulated crud on the flap, it will need re-visiting in the future.
  6. Re: Throttle body
    Feb 2017
    Rochester
    Quote Originally Posted by philipharmes View Post
    The problem is the seal around the electrical part has completely disintegrated. I doubt very much I’ll be able to get a new seal for it.
  1. Question help with throttle body fix
    By Rukks in forum Chat - Completely Off Topic
    Last Post: 28-06-2018, 05:17 PM
  2. Please Help Throttle body
    By danny851 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2017, 01:44 AM
  3. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  4. Throttle body
    By tom tom in forum Polo - Derby - Lupo - Fox
    Last Post: 06-11-2012, 09:17 PM
  5. throttle body on 1.8 gti
    By peterdenson in forum Chat - Anything with wheels
    Last Post: 22-05-2008, 08:16 PM
