Thread: A6 C7 Auto Taailfate Issues
  1. A6 C7 Auto Taailfate Issues
    Apr 2020
    Nottinghamshire
    Hi Everyone,
    My auto tailgate has started to play up. You used to press the external button once and the tailgate automatically opened fully. Now you press it once but it only opens but doesn't lift at all. Press the button again and it only opens 3/4 open not quite fully open. Press the close button on the underside and it closes fine.
    Thanks for all your advice in advance. I very much appreciate you taking the time to respond.
    CRaig
  2. Re: A6 C7 Auto Taailfate Issues
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    There is a reset procedure, and an adaptation procedure to set the maximum height the tailgate will open. I think it's in the owner's manual, but I think Googling it produces results.
    If this doesn't work, it may be worth pulling off the roof trim and inspecting the motors and linkages for anything that has seized, come loose or broken.
  3. Re: A6 C7 Auto Taailfate Issues
    Apr 2020
    Nottinghamshire
    Thank you, Looked on YouTube and manged to sort the boot to open fully. Still cant manage to change it to open with one press of the button like it used to. I will keep looking
    Craig
  4. Re: A6 C7 Auto Taailfate Issues
    Feb 2013
    Finland
    13 Post(s)
    It does this sometimes, usually on a warm day or if she is transversely tilted. Also if the gas springs are reaching their end of life.
  5. Re: A6 C7 Auto Taailfate Issues
    Apr 2020
    Nottinghamshire
    Thanks for the tip. Much appreciated.
  6. Re: A6 C7 Auto Taailfate Issues
    Jun 2013
    Oxford
    Quote Originally Posted by Allroad-CRaig View Post
    My 2013 Avant started doing this about 4 years ago. When pressing the fob, internal button or external release you could hear the lock release but the tailgate did not always open. Sometimes when it did, it only opened half way. It was possible to force the tailgate gate open and reset the close switch by holding it down until it beeped. It would then work properly until it had been sitting overnight, when it would go back to square one.
    The car went in for a service at an Audi dealership. It produced an error code which prompted them to change the close switch at a cost of about £100. Everything worked for about a year and now the problem has returned.
    I find pressing the external button and "encouraging" the tailgate with a little upwards pressure enables it to work properly. So I just live with it. It's the only thing that has gone wrong over 7 years of ownership so I forgive it.
    By the way, replacing the switch doesn't look too difficult and the part is cheap if you can be bothered.
  7. Re: A6 C7 Auto Taailfate Issues
    Apr 2020
    Nottinghamshire
    This works -
  1. Please Help B7 Auto Gearbox Issues
    By Craig'yboy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-01-2016, 10:28 AM
  2. Sharan Auto Box Issues.
    By delphius1 in forum Touran - Sharan - Caravelle
    Last Post: 31-01-2011, 06:23 PM
  3. Auto dim mirror issues.
    By benjie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-11-2010, 09:45 AM
  4. Auto Issues
    By bobcoy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-02-2010, 11:57 PM
  5. Please Help W Reg V6 TDI Auto Issues
    By mr-mixalot in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-12-2008, 05:39 PM
