Thread: Correct sealant for the sump / Oil Pan
  1. Correct sealant for the sump / Oil Pan
    Oct 2009
    Malvern
    I need to remove my sump / oil pan as it's developed a rush spot which I think will turn into a hole if a poke it :-( Was thinking of just drilling a hole and fitting a nut and bolt with a sealing washer, should do for now but I'll need some sealant to be able to re-fit it? What is the correct stuff to use on this please? Thanks.
    Audi A4 3.0TDI Q SE Lava Grey + B&O, Audi Drive Select, Sports Seats, Sun Roof, DVD Sat Nav Plus, Blue Tooth Phone Prep, Audi Hill Assist, Rear Parking Aid, Electric Seats, Light Pack, Audi Audio Interface, MMI etc... and 4 Halfords Bulbs lol....
  2. Re: Correct sealant for the sump / Oil Pan
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I would think it would be best to replace in one operation rather than remove and do the job twice, but I guess at the moment its going to be hard to get the replacement part! Again, I dont think you may get this sealant but when I worked at VW this was a current part number of the sealer for sumps if I remember correctly 176 404 A2 ( Silicone sealant).
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Correct sealant for the sump / Oil Pan
    Feb 2020
    Bradford
    40 Post(s)
    If its holding up right now I'd just keep an eye on it until you can get the right part. I have some rust converter which I may put on it to slow it down temporarily. If its already leaking even a little bit then I would treat it as an emergency
    Last edited by Roverfan; 04-04-2020 at 08:52 PM. Reason: Didn't realise the sealant is the official gasket!
  4. Re: Correct sealant for the sump / Oil Pan
    2008 Post(s)
    Quote Originally Posted by Pauls898 View Post
    Was thinking of just drilling a hole and fitting a nut and bolt with a sealing washer.
    How will you get behind it to put the bolt through the hole?
    Anyway, the special sealant is D 174 003 M2and costs £43.27 and the sump itself is 059 103 602 K and costs £131.59 if I have guessed the car correctly.
  5. Re: Correct sealant for the sump / Oil Pan
    Oct 2009
    Malvern
    Thanks, yes I was quoted those prices at Audi Dealer.
  6. Re: Correct sealant for the sump / Oil Pan
    Oct 2009
    Malvern
    Hi yes that's the reason for removing the sump, as nowhere's open at moment to get it welded, I thought if there is clear space behind, I would simple stick a nut and both though the hole with a sealing washer and replace the sump, I've got a to do and oil service anyway so would like to address this issue before I replace the oil. It's only a small buble so hoping it wouldn't be too big a hole if there is indeed a hole there once I address this rust spot?Oil Service 37,098 miles with Rust Spot_crop.jpg
  7. Re: Correct sealant for the sump / Oil Pan
    Oct 2009
    Malvern
    Thanks I have ordered a tube from Amazon, then if I find I don't require it as if no hole is found under that blob on the sump, I can simply return it :-) Thanks
  1. Which sealant for sump on 3.0 tdi ASB?
    By Quattro-Charlie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2017, 11:32 AM
  2. Do i need to use genuine Audi sealant when putting on sump pan
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2014, 10:03 PM
  3. Replies: 2
    Last Post: 10-04-2011, 08:54 PM
  4. Special sealant for sump?
    By paul b in forum Ibiza - Cordoba
    Last Post: 21-05-2010, 08:47 PM
  5. wax or sealant.
    By simba in forum Chat - Anything with wheels
    Last Post: 28-05-2008, 01:11 AM
