Thread: New power steering fluid a bright lime green colour
Results 1 to 8 of 8
  1. New power steering fluid a bright lime green colour
    Liverpool
    11 Post(s)
    Bit of help please guys
    Replaced the PS pump and belt on my 2003 3.0 petrol v6, mrs has driven it about 20 miles maximum this week and went to check the fluid level (just to be sure it hadnt dropped since the pump change) and it was actually lime green in colour? Not the clear, dark green colour it was when we filled it, but a bright, lime green colour
    Any ideas??
  2. Re: New power steering fluid a bright lime green colour
    132 Post(s)
    1979 Post(s)
    Did you use COVID-19 fluid?
  3. Re: New power steering fluid a bright lime green colour
    Liverpool
    11 Post(s)
    Starting to think I may of Crasher, it sounds that bl00dy sick at the moment....
  4. Re: New power steering fluid a bright lime green colour
    Mar 2016
    Minervois, France
    54 Post(s)
    Could it be full of tiny air bubbles, making it look lighter coloured?
    EDIT: You could try sucking out a small amount - I use a hypodermic syringe for this (without the needle), and let it settle in a clear glass container.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  5. Re: New power steering fluid a bright lime green colour
    132 Post(s)
    1979 Post(s)
    I would do an engine running flush (do you know what I mean?) and refill.
  6. Re: New power steering fluid a bright lime green colour
    Liverpool
    11 Post(s)
    Crasher, sadly i dont know the 'engine running flush' - Please do tell, I am all ears
  7. Re: New power steering fluid a bright lime green colour
    Mar 2016
    Minervois, France
    54 Post(s)
    I just tried shaking a half bottle of Fairy liquid. It definitely looks much lighter. So might be worth a try - the pump could be sucking in some air through the feed from the reservoir.
    This would also increase the volume, is the level noticeably higher?
  8. Re: New power steering fluid a bright lime green colour
    132 Post(s)
    1979 Post(s)
    Quote Originally Posted by FrenchAudi View Post
    What you get upto in your lock down time is none else's business...
    The running flush is simples, take off the reservoir rack return hose and plug the fitting, then extend the return to a drain bucket. Run the engine and poor a couple of litres of fresh fluid through into the bucket and then reconnect and re fill.
  1. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  2. Power Steering Fluid Top-Up
    By gregpot2000 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-01-2013, 11:27 PM
  3. power steering fluid
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 05-02-2011, 06:24 PM
  4. power steering fluid ?
    By Dianne1 in forum Chat - Anything with wheels
    Last Post: 27-01-2008, 10:16 PM
  5. Power steering fluid
    By passat guy in forum Passat - Archive Topics
    Last Post: 15-09-2006, 09:54 PM
