Thread: CBA diesel in oil
Results 1 to 9 of 9
  1. CBA diesel in oil
    Dublin
    Hi Guys,
    I have a 2010 Passat B6(CBAB engine)that has diesel getting into the oil. Car is driving fine, No issues but checked level on dipstick and was way over max fill line, I've done good bit of research on the common rail engine and it's either pointing to the tandem pump seals or injectors, I've had a good poke around and no sign of any fluid around the tandem pump, do injectors usually "go" on these engines? Is it a case of replacing the seals or do the injectors crack and need replacing? Milage on car is 170k miles but has been well looked after. Any ideas would be greatly appreciated.
    Darren
  2. Re: CBA diesel in oil
    131 Post(s)
    1973 Post(s)
    It does not have a tandem pump, that is a PDTDI.
  3. Re: CBA diesel in oil
    Dublin
    Oh I thought they had one the RHS of the head. Could you shed any light on the injectors? Do they generally fail requiring replacement or would new seals fix the issue?
    Thanks for the help
  4. Re: CBA diesel in oil
    131 Post(s)
    1973 Post(s)
    The pump on the head is only a vacuum pump. Do you get smoke at idle or are having DPF issues?
  5. Re: CBA diesel in oil
    Dublin
    Ah ok. No smoke at idle. I did notice a few puffs of smoke when accelerating away from slow speed. No DPF issues
  6. Re: CBA diesel in oil
    131 Post(s)
    1973 Post(s)
    Fuel should not be able to get into the oil with CR unless it is excess combustion fuel and that usually leaves the idle smoke clue. Firstly you need to have the leak off rates checked. Be aware that during this the return rail often falls to bits so factor this in with the costs.
  7. Re: CBA diesel in oil
    Dublin
    Thanks for the replies. Ive had a closer look today and one of the o-rings around injector 1 looks frayed and definitely leaking something. I've attached a picture. Would this cause diesel into oil ?
  8. Re: CBA diesel in oil
    131 Post(s)
    1973 Post(s)
    It is plausible, it won't harm to change the seals but it is not a quick job and often the return rail falls to bits.
  9. Re: CBA diesel in oil
    Dublin
    Thank you for the help. Your knowledge on here is super. Looks like that top plate part is separate and comes with a seal. I'll get a leak test done on the injectors first of all and go from there and report back
    Darren
  1. Replies: 2
    Last Post: 07-01-2018, 07:04 PM
  2. 2.0 diesel touran, diesel smell in car when idolling
    By neilstouran in forum Touran - Sharan - Caravelle
    Last Post: 13-06-2014, 11:21 PM
  3. 2005 audi a8 runs on water & diesel and save you 50% on diesel
    By OddBallBoy in forum Chat - Anything with wheels
    Last Post: 10-05-2013, 11:23 AM
  4. Question A3 2.0 TDi Sport DSG Diesel Auto /Diesel consumption
    By maksinx in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-08-2009, 10:13 AM
  5. Differecne Diesel Golf GT 2.0 & Diesel GT 2.0 SPORT ?
    By johnd1881 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-08-2008, 07:33 PM
