Thread: problem with Variable valve timing-maybe
  1. problem with Variable valve timing-maybe
    Mar 2020
    Sofia
    Hello,
    thank you for wellcome.
    I have problem with the power on car.Why VCDS say:Specification: "System not OK".
  2. Re: problem with Variable valve timing-maybe
    Mar 2020
    Sofia
    if the phaser gear is blocked, can it therefore spell it out "Syst.not Ok".
  3. Re: problem with Variable valve timing-maybe
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    If you scan it are any faults logged?
  4. Re: problem with Variable valve timing-maybe
    Mar 2020
    Sofia
    Quote Originally Posted by VAG-Abound View Post
    Thanks for the reply.
    That`s the problem no faults codes.And the car is sluggish from idle rev to high rev.
    Only Check Engine Light and EPC are on when ignition on(engine is not running).
    For me the problem is intake camshaft-but what kind is?
    What is these 110.60 degrees?
    They never change.
  5. Re: problem with Variable valve timing-maybe
    Mar 2020
    Sofia
    or Timing chain is jumped 1 or 2 teeth.
    For other thing I don`t remind.
    Today i tested solenoid n205-it works(clicking).
    You ?
  6. Re: problem with Variable valve timing-maybe
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Sorry, beyond my knowledge. There are other jumped belt threads though see if they help.
  7. Re: problem with Variable valve timing-maybe
    Mar 2020
    Sofia
    for jumped chain that I guessed,but maybe is not she.
    Generally I have problem with the power of engine.If the chain is jumped-ECM says "wrong correlation".I don't have any fault codes.
    Thank you for answers
  1. 2012 GTI 2.0 Tsi. variable valve timing solenoid
    By adam.rice09 in forum Golf MK6 - 2009 - 2013
    Last Post: 12-09-2018, 01:21 AM
  2. Variable valve solenoids
    By a4votex in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2015, 09:57 PM
  3. Please Help 3.0 v6 variable vale problem
    Last Post: 10-02-2015, 09:50 PM
  4. Question T4 2.4 Valve timing
    By Johnjum in forum The Commercial Range
    Last Post: 24-06-2008, 10:34 PM
  5. A4 1.8petrol Variable Valve Timing
    By lml34 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-11-2007, 12:00 PM
