Thread: How to remove Pins from a Steering wheel Connector A4 B6?
Results 1 to 10 of 11
  1. How to remove Pins from a Steering wheel Connector A4 B6?
    Jul 2019
    Croatia
    Hello. I saw this tread https://www.audizine.com/forum/showt...e-Stage-Airbag .
    I bought everything and now I need to switch my wires on the yellow connector for it to work properly. Can anyone help me, send a video or something on how to take those pins out. I just cant figure it out, and yes i did remove the purple thing.
    I got the Lisle 56500 Terminal Tool alo.
    Here are the images of the connector: https://imgur.com/a/2d0tJpA
  2. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    For some reason your text is nearly-white on white. I thought you were just sharing a tip .
    You should find the wires wiggle back and forward a bit. Push them into the housing (so the wrong way for removal). The extraction tool should then be able to slip in from the end you show on the photo (maybe into those narrow looking slots?) and press down the retaining "spring tab". It can't do this if you pull on the wire while putting the tool in. Give it a little jiggle out / in / out while moving the removal tool up / down a bit and hopefully the wire will pop out.
    You may need to ease the retaining tab back up to be ~0.5mm proud of main pin body so it will then click into new housing.
  3. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Jul 2019
    Croatia
    There are 3 pictures.
    The problem is the hole is just so small i can only fit a needle in it. I cant push it more in. I dont know with what should i try to get it out.
  4. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    So there are . If a suitable bit of metal or plastic won't go in that slot (bit of milk bottle? - prob too soft; sliver of Coke can?) are they perhaps intended to be released from the other side? In pic 2 there's a sort of zig-zag effect between say the green and white wire. Can you see an edge of the retaining tab against the "high" part, and use your needle in the "low" part to flick it?
  5. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Can you see a code on the yellow housing in super small raised moulding? Might help to take a look at what pins / terminals go in there.
  6. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
  7. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Jul 2019
    Croatia
    Yeees, thanks. But now when i figured out how to do it. It goes out only this much: https://imgur.com/a/y9BUymK
    I'm trying so hard. But it just wont go out..
  8. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    My guess would be that the tab is snagging on something else. Can you see where the tab is?
  9. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Jul 2019
    Croatia
    https://imgur.com/a/EY7Trhx I think that this is it. But im not sure. Everyone goues like 60% out. But the tab just wont come out..
  10. Re: How to remove Pins from a Steering wheel Connector A4 B6?
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Looks to me like you need a fine needle to try and go in though the little notched gap to press the tab down. See if uour extraction tool can travel all the way through an emty slot. If so try and get it to follow the pin as it moves out to keep the tab pressed down.
  1. Please Help Connector pins /spades
    By hackman in forum Golf MK4 - 1999 - 2004
    Last Post: 18-07-2013, 09:16 AM
  2. How To Remove the steering wheel
    By gmp777 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-01-2011, 07:03 PM
  3. How To remove steering wheel
    By matt_80 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-02-2010, 08:42 PM
  4. Audi A4 Maf connector. How many pins?
    By m8gic in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2009, 04:56 PM
  5. Question How do you remove the steering wheel from a T5?
    By paul b in forum The Commercial Range
    Last Post: 16-07-2008, 11:14 PM
