Thread: Multiple errors
Results 1 to 10 of 17
  1. Multiple errors
    Mar 2014
    Nottingham. UK
    The errors have happened one after another within 30seconds.
    •Parking brake malfunction.
    •Stabilisation programme (esp) and Abs Fault.
    •Headlight control range defective.
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  2. Re: Multiple errors
    Oct 2019
    Peterborough, England
    23 Post(s)
    Multiple errors like these usually turn out to be battery/power related.
    Might be worth changing the battery - is it the same age as the car? It will also need coding to tell the computers the battery has been changed.
    Hopefully.....
  3. Re: Multiple errors
    Mar 2014
    Nottingham. UK
    I changed the battery 2 yrs ago. I was unaware you have to have them coded. Also Ive not had a battery low light on at all.
  4. Re: Multiple errors
    2007 Post(s)
    Battery low light? whats that? Anyway, quite likely to be water in the right of the boot inner wing. If it was scanned with full VCDS, you get a volate report at the end and many controllers log the voltage when a fault occurs and produce this in the report.
  5. Re: Multiple errors
    Mar 2014
    Nottingham. UK
    Also i just changed the related fuses and everything worked as it should for about a minute and then it reverted back to the errors.
    Ive got it booked in for diagnostic on monday. Hopefully nothing too expensive!
  6. Re: Multiple errors
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    I had this minutes before my alternator packed in.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  7. Re: Multiple errors
    Mar 2014
    Nottingham. UK
    Where is the parking brake module located?
  8. Re: Multiple errors
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    In the Passat it's in the centre consol between the front seats, rear of the gear lever.
    I would guess it's in the same place in the Audi.
  9. Re: Multiple errors
    2007 Post(s)
    In the boot in the right corner below floor level under the trim
  10. Re: Multiple errors
    Mar 2014
    Nottingham. UK
    Here are the scan results.
    More errors than what I was expecting!
    01-Engine Management:
    U111300 Function limitation due to received malfunction value.
    03-Brake Electronics:
    00290 ABS Wheel speed sensor, rear left - G46 Electrical problem in circuit.
    08-Airco:
    01273 Fresh air blower (V2) Open circuit/Short with ground - Intermittent.
    09-Central Electronics:
    01497 Blinkers Front Right - M7 Open circuit - Intermittent.
    00908 Control Module for wiper motor mechanical malfunction - Intermittent.
    17-Instrument Cluster:
    00003 Control Module No or Wrong Adaptation.
    19-Diagnostic Data Interface-Gateway:
    01327 ECU for Parking Brake Help - J446 No Signal/No communication - Intermittent.
    53-Parking Brake:
    01316 ABS control module not a plausible signal.
    55-Level Control Xenon Lights:
    01316 ABS Control Module Read Trouble Codes - Intermittent.
    76-Parking Help:
    01546 Sensor for parking aid rear mid - left (G204) open circuit/short with ground.
  1. A6 3.0TDI Avant 2005 ESP Light and multiple VAG-COM errors
    By hydrogenet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-02-2020, 12:37 PM
  2. Replies: 6
    Last Post: 25-07-2019, 07:18 PM
  3. Multiple fault code and errors full read out
    By bashman40 in forum VCDS - General Questions
    Last Post: 08-07-2019, 09:10 AM
  4. Multiple errors- TMPS, ABS, ESP, PARKING BRAKE
    By bubak_here in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-09-2018, 01:33 PM
  5. Please help with errors
    By cip82 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-01-2017, 03:44 PM
