Thread: Idle Problem, throttle body cleaned, what else could it be?
Page 5 of 5 FirstFirst ... 345
Results 41 to 50 of 50
  1. Re: Idle Problem, throttle body cleaned, what else could it be?
    #41
    Mar 2016
    lecce
    Quote Originally Posted by luckysquid View Post
    hi, I have mk4 1.6 sr akl but I don't access on running speed menù.. all group in adaption says "not avaible" there is a solution?
    ps. I use vag com 309
    update: I think that problem is login code: I try "12233" but I have a error.. What is the login code for 1.6 sr akl?
    thanks
  2. Re: Idle Problem, throttle body cleaned, what else could it be?
    #42
    131 Post(s)
    1974 Post(s)
    This thread is eight years old and VAG COM 309 is even older! What are you trying to achieve? If there are any AKL login codes, the latest VCDS has them as pop up help boxes in many cases, although with a heavy USA market bias but as far as I am aware there are no login codes for the AKL.
  3. Re: Idle Problem, throttle body cleaned, what else could it be?
    #43
    Mar 2016
    lecce
    hi, I want to increase idle speed. all golf 4 can increase idle speed from "engine-adaption-channe01" (hxxp://www.ross-tech.com/vag-com/cars/vwmkIV.html) but im my mk4 i saw "not available" in all channel of engine.
    Vag com 309 is old but is compatible with mk4.
    Do you think that with new vcds I can set idle speed?
    thanks
    PS. my mk4 is italian year 2000
  4. Re: Idle Problem, throttle body cleaned, what else could it be?
    #44
    131 Post(s)
    1974 Post(s)
    The idle speed for an AKL cannot be adjusted. If you have no fault codes but a low idle, clear the learnt values in "Adaptation 10, group 00" and do this three times. Then go into basic settings and carry out group 098 and allow it to run for 30 seconds, then exit and turn off the ignition for 30 seconds, then try it again.
  5. Re: Idle Problem, throttle body cleaned, what else could it be?
    #45
    Mar 2016
    lecce
    The idle speed for an AKL cannot be adjusted. If you have no fault codes but a low idle, "clear the learnt values in "Adaptation 10, group 00" and do this three times. Then go into basic settings and carry out group 098 and allow it to run for 30 seconds, then exit and turn off the ignition for 30 seconds, then try it again."
    thanks, this proceduire is with ignition on or off? "The idle speed for an AKL cannot be adjusted. If you have no fault codes but a low idle, clear the learnt values in "Adaptation 10, group 00" and do this three times. Then go into basic settings and carry out group 098 and allow it to run for 30 seconds, then exit and turn off the ignition for 30 seconds, then try it again."
    Why AKL cannot manipulated idle speed?
  6. Re: Idle Problem, throttle body cleaned, what else could it be?
    #46
    131 Post(s)
    1974 Post(s)
    thanks, this proceduire is with ignition on or off? Why AKL cannot manipulated idle speed?
    It is ignition on, engine not running. The software engineers who wrote the program did not provide a value for adjusting the idle like certain others cars have such as my AUQ engined 2003 Octavia, I have set my idle to the maximum because it is smoother. Engineers set the idle is set as low as possible to reduce emissions.
  7. Thumbs up Re: Idle Problem, throttle body cleaned, what else could it be?
    #47
    Mar 2016
    lecce
    very thanks tomorrow I will try to throttle alignment
    PS. my idle speed at warm is 780-800 rmp, but car cold is around "850-900" and car is more more smoother. Unfortunately I cannot set this
  8. Re: Idle Problem, throttle body cleaned, what else could it be?
    #48
    131 Post(s)
    1974 Post(s)
    That is how it should be and how it will have to be. One point to make, be sure that the throttle cable is not too tight and holding the throttle slightly open when released. AKL throttle bodies are very unreliable and often need replacing.
  9. Re: Idle Problem, throttle body cleaned, what else could it be?
    #49
    Mar 2016
    lecce
    thanks how I loosen throttle cable? so if throttle cable is slack car is slightly accelerated?
  10. Re: Idle Problem, throttle body cleaned, what else could it be?
    #50
    131 Post(s)
    1974 Post(s)
    Have an assistant press the throttle pedal all the way down and hold it, feel the cable at the throttle body end to see if it feels to tight. If it needs adjusting, remove the circlip and with the throttle fully depressed, pull the cable through the rubber grommet until it is tight and fit the circlip on the last visible position. Then with the pedal released, move the circlip along one more position. Now check to make sure the cable has a little slack at the throttle body fitting, the cable must not open the throttle at all.
  1. Golf Mk3 Throttle body
    By Slim in forum Golf MK3 - 1993 - 1999
    Last Post: 23-08-2007, 10:34 PM
  2. Golf Mk4 1.6 SR Throttle Body Cleaning
    By randall977 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2007, 09:48 PM
  3. Throttle body fault
    By Jay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-02-2007, 02:51 PM
  4. Cleaning throttle body
    By zenmaster in forum Audi A4 - Archive Topics
    Last Post: 05-02-2007, 02:53 PM
  5. throttle body noise golf gti 2003 (180)
    By minky in forum Archive posts
    Last Post: 05-01-2007, 07:43 AM
