Thread: ECU issue
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: ECU issue
    Jun 2008
    If a new ECU cures it I will be genuinely astonished. I distrust the acronym OEM, it makes me very suspicious they are covering their tracks having fitted an aftermarket unit as if later it is found to not be a genuine VAG TPS supplied unit and it tuns out to be a Pierburg 7.09720.00.0 they can quite correctly say they were telling the truth as Pierburg is THE OEM (Original Equipment Manufacturer) of the factory fitted part BUT I have had two of these fail on me, one before we even got the car off of the lift.
    I have taken a screenshot of this to show the garage next week Crasher. Thaankyou for your help and we will see exactly what they have fitted.
    If it ain't broke leave it alone!!!
  2. Re: ECU issue
    Jun 2008
    Well Crasher you were utterly correct with your diagnosis. I passed on all your info to the garage and it became apparent the EGR fitted was a overhauled item hence the original cheaper price.
    So i insisted we went to TPS for a Gen VAG item and hey presto no more fault. So the morale to the story here was going to VW would have been the best approach considering how much money was spent. The thing here was the replacement item tested fine on the car, everything worked as it should but and its a big but for whatever reason these items just dont work when fitted to the car?? It would be interesting to see what actually caused these to fail??
    The one plus thing to all of this is the mileage on the car has been kept down as i used the garages courtesy cars a lot. And the other is an ECU that was badly corroded and could have potentially led to major problems down the line. Also now due to the current pandemic and the devastation its had on my industry (Aviation/Airlines) i will be keeping the car for at least another year so i know at least these two items will be good.
    Every day is a school day and thankyou again Crasher. Much appreciated.
    1 1 0
  3. Re: ECU issue
    134 Post(s)
    2005 Post(s)
    When these started failing about 5 years ago we bought the first one from ECP which was an exchange and it lasted a week. As compensation ECP replaced it with an OE Pierburg and that didn’t even work long enough to get the car off the lift... We then fitted a genuine one and we still look after this car and it is fine. Having said that, last year we had to do one we had done three years previously with a genuine unit and VW UK were not interested in helping so the customer had to pay for a new one and I felt a bit aggrieved for her.
  1. Issue with 2019 Q7 50 TDi - Hesitation from speed sensor issue
    By marcusjames in forum Q7 - 4M Forum - 2016 -
    Last Post: 07-02-2020, 06:01 PM
  2. Please Help B6 2.0 tdi Cr 140. EGR/IMF issue
    By Majorlook in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-06-2019, 11:04 PM
  3. a6 oil sensor issue and airbag issue
    By 2400 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-12-2012, 11:26 AM
  4. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  5. 05 2.0tdi Idle issue & '97 1.8 engine issue
    By dbbear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-08-2009, 02:11 PM
