Thread: a6 c7 2.0 tdi starts but shuts down after a few seconds
  1. a6 c7 2.0 tdi starts but shuts down after a few seconds
    Jun 2024
    Sweden
    Hello, As I wrote in the title, I have an Audi a6 c7 2.0 tdi and there is something wrong with it. I drove the car and it lost power and shut down, after this it starts for a few seconds but shuts down,no error code no engine light nothing.
    Hope someone can help with this
    Thank you in advance
  2. Re: a6 c7 2.0 tdi starts but shuts down after a few seconds
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    There is normally a code to give you a clue, what did you scan it with?
    Could be blocked DPF or Cat Collapsed, open the oil cap and try to start it.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: a6 c7 2.0 tdi starts but shuts down after a few seconds
    Jun 2024
    Sweden
    No there are no error codes no light on the display, I use ODIS, have tried with oil cap it was the same
  4. Re: a6 c7 2.0 tdi starts but shuts down after a few seconds
    Mar 2013
    Reading
    31 Post(s)
    The car shutting down on its own, without any codes, is truly bizarre. You sure there is nothing stuffed in the exhaust?
  5. Re: a6 c7 2.0 tdi starts but shuts down after a few seconds
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    Look in the diagnostic measuring blocks for the fuel rail pressure, and see what that does when you start it. It should be reasonably steady for a given load and RPM, but if it wildly bounces around, then there is a problem. More likely the pressure regulator, but possibly the pressure sensor, or the pump itself. Another thing- is the fuel supply good? clean filter, contaminated fuel etc?
  6. Re: a6 c7 2.0 tdi starts but shuts down after a few seconds
    Jun 2024
    Sweden
    I changed the fuel filter, when I remove the fuel hose and turn on the fuel pump, fuel comes constantly, when I start the engine and look at the fuel pressure, it comes up to 510bar before the engine shuts down, and that's what's driving me crazy no error codes no lights on the display
  7. Re: a6 c7 2.0 tdi starts but shuts down after a few seconds
    Jun 2024
    Sweden
    Is it possible that it is the camshaft sensor without showing an error code?
  8. Re: a6 c7 2.0 tdi starts but shuts down after a few seconds
    135 Post(s)
    2042 Post(s)
    I would suspect the crankshaft speed sensor known as the G28, these are well known for failing and not leaving a code. View the rpm data from the ECU to see if it drops to 0 instantly as it is cutting out.
  1. Question Golf MK5 starts and shuts off instantly?
    By hussnainh8 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-11-2019, 09:41 PM
  2. Please Help Cut out, starts ok but cuts out after 10 seconds
    By Tack271 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-04-2017, 06:34 PM
  3. 2.0 TDI 170 ps starts then cuts out after 3 seconds, after limp home episode.
    By mowcopds in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-01-2014, 06:24 AM
  4. Please Help A3 starts for a few seconds - immobiliser?
    By bletha3 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 17-01-2010, 11:10 PM
  5. Audi 80 auto 1.8 starts for 2 seconds then stops
    By timnewton30 in forum 80 - 90
    Last Post: 10-08-2008, 05:35 AM
