Thread: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 114
  1. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #71
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Quote Originally Posted by liam walsh View Post
    Get the dealership to diagnose it . You've had a lot of work done in the area it could be a cracked vacuum hose, bad sensor , loose plug, damaged wire. Tell them you didnt have the problem before they worked on it and now you have . You know this because you did your vcds scans before and after.
    Yiu are right. Will call them.
  2. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #72
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Booked on Tuesday.
  3. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #73
    Dec 2008
    19 Post(s)
    Quote Originally Posted by Sambor11 View Post
    Booked on Tuesday.
    What sid Mr Audi say?
  4. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #74
    Sep 2015
    Forres, Scotland
    23 Post(s)
    It was damaged hose from ccoolant container. I asked them as well one more time to check for fault codes specially for sensor G450. Should get call today later on.
  5. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #75
    Dec 2008
    19 Post(s)
    The plastic couplings on that line crack easily . That line is about £50 if I remember correctly.
    Keep us updated with their findings on the G450 issue.
  6. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #76
    Sep 2015
    Forres, Scotland
    23 Post(s)
    I just spoke with mechanic. He said that last time probably disconnected connector abd didn't clear fault codes. They clear now. When I'll get my car back will check one more time.
  7. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #77
    Dec 2008
    19 Post(s)
    You can see the date time and mileage when the fault logged if you have a record kept of the vcds fault . Then you can see if it was while in the dealers or afterward.
  8. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #78
    Sep 2015
    Forres, Scotland
    23 Post(s)
    It was in Audi garage. They replaced leaking coolant hose £18, cleared fault codes and now everything is fine. But. I bought from Audi boost pressure sensor on Thursday and today I want to replace but when I opened box I was little confused. In my car is sensor 03L906051B with two pipes and sensor which I got is 04L906051K with one pipe ( picture below). Somebody can tell me what's going on guys????
  9. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #79
    Sep 2022
    Milton Keynes, UK
    How do you actually test the MAP sensor before you buy one, Liam ? I have Autel MK808 and VCDS, but don't think the sensor will be short to ground. Am I looking for some deviation from normal values ? And if so, what are the normal operational values ?
    Thank you
  10. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #80
    Feb 2009
    Ireland
    6 Post(s)
    I don't think you can test MAP sensor in an easy way, unless it has completely failed or deviates from atmospheric pressure.
    I'm going through the same vows now, have both the P2002 and AdBlue with limited mileage faults, but garage is taking a look at it as it is still under warranty. Quite upsetting tbh - thought I've got a good untouched example.
  1. Question Heater Matrix Removal and cleaning
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2017, 07:57 PM
  2. Replies: 19
    Last Post: 19-07-2016, 11:51 AM
  3. Question EGR Removal for cleaning/replacement
    By Ant7t5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 08:26 PM
  4. Oil cooler removal
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2009, 03:37 PM
  5. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 09:46 PM
