Thread: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 114
  1. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #51
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Go to Audi UK first, write a clear, concise, well reasoned letter and send it registered post. Don't rant, don't threaten just lay the problem out and ask for a response within a reasonable time frame. Have a talk to citizens advice as well and document everything. If you get no response then elevate it up the line. Good luck.
  2. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #52
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Quote Originally Posted by Whippy53 View Post
    Thanks for advice!
  3. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #53
    Dec 2008
    19 Post(s)
    Quote Originally Posted by Sambor11 View Post
    They don't know why this happened. Told me contact Audi UK. I will do but I think is wast of time. Maybe write to Audi Germany. Anyone can suggest to whom contact in Germany? A lot of people have this problem. Not only in UK.
    What was the bill? DPF and Egr cooler plus labour you must be close to 3k .
    Call this number 0800 699 888 and explain your case. Go from there. They're usual get out clause for this is your driving profile is not compatible with a modern DPF equipped diesel.
    For comparison my car had 136k miles on it when I took out the cooler and dpf ( because audi tech notice says inspect EGR cooler first for P2002 faults) . The cooler was only slightly dirty , I changed mine because I didnt want to take it out again . My DPF was clear but reading close to 75% max ash so I got it cleaned while I had it all apart.
    In the end my problem was the MAP sensor .
  4. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #54
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Quote Originally Posted by liam walsh View Post
    Payed £882 ( they discounted me 33%)just for cooler. DPF was ok. Car is running now smooth. Did you have fault with MAP sensor, or you just replaced it?
  5. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #55
    Dec 2008
    19 Post(s)
    Replaced sensor due car going into limp mode every now and then.
  6. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #56
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Replace even no faults?
    I can't find 04L 145 049 AE. Without AE there are but no with AE.
  7. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #57
    Dec 2008
    19 Post(s)
    A mechanic with alot of experience on this particular generation of VW engine told me that if you have intermittent limp mode and a P2002 fault the first , easiest and cheapest attempt at a fix is replace the map sensor. After that go and look at EGR cooler and DPF.
  8. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #58
    Dec 2008
    19 Post(s)
    AE would be the revision status of the part. Ask the parts dept at your AUDI dealership. I replaced that exact part number during the summer.
  9. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #59
    Sep 2015
    Forres, Scotland
    23 Post(s)
    Just pop up info on my dashboard today 'coolant low level'. Need to call Audi garage. Never had this before. Start leaking after they replaced egr valve cooler.
  10. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #60
    Dec 2008
    19 Post(s)
    Some very tricky limited access water pipe clamps down in that area.
  1. Question Heater Matrix Removal and cleaning
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2017, 07:57 PM
  2. Replies: 19
    Last Post: 19-07-2016, 11:51 AM
  3. Question EGR Removal for cleaning/replacement
    By Ant7t5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 08:26 PM
  4. Oil cooler removal
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2009, 03:37 PM
  5. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 09:46 PM
