Thread: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 114
  1. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #91
    Feb 2009
    Ireland
    6 Post(s)
    Sorry. I do get a bit of that too!
  2. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #92
    131 Post(s)
    1974 Post(s)
    I couldn't remember the correct spelling so Googled it and the result nearly made me fall off my chair, it is a bizarre phobia and I have no idea what started it.
  3. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #93
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Quote Originally Posted by nordic_b View Post
    Hey guys, as promised, few pictures.
    I'm not totally convinced it was badly blocked, but I let you and the car judge. Need to drive more for this fault to reappear.
    Attachment 38745 Attachment 38746 Attachment 38748 Attachment 38747
    After. You can see dimples (by design) inside the tubes, that probably contribute to blockage.
    3 bottom tubes are straight through, perhaps for oil passing through easier?
    I rinses it in the oven degreaser concentrate in the water (nasty stuff, wear gloves if you use it) for about 10 minutes. It attacks lots of stuff, including metals, so don't leave it overnight Urea crystals and everything have dissolved.
    Attachment 38749
    I opened up the egr valve to see how plastic gears look, they looked ok, but greased them with non-petroleum grease.
    Attachment 38750
    Cleaned everything and assembled back.
    It ruined my hands, they look like I got attacked by 10 hungry cats.
    This freak of engineering looks like a nuclear reactor.
    Attachment 38752
    If anyone is going to attempt this work, 15-20 hours, as mentioned, is probably about what it takes if to do it properly, e.g. respecting torque specs, using copper grease, etc.
    You'll need to drain coolant or, like I did, drained liter or 2 from the cooler itself.
    You may also need:
    - Inspection mirror
    - Magnetic pickup - you'll drop endless stuff
    - Endoscope helps too, some places/bolts are not visible from any angle - who designed this?
    Tools that I really needed and did not have:
    - dedicated hose clip pliers - absolutely essential
    - various lengths torx bits
    Parts I had to remove/detach:
    - Air filter assembly / front rad cover
    - Top brace
    - Bottom cross member
    - Disconnect downpipe from the gearbox mount
    - DPF assembly detached from the exhaust and the turbo, did not need to remove
    This allows to wiggle things out in some magic manner, rubic's cube springs to mind.
    Attachment 38751
    Looks about as bad as the pictures in the Audi TSB I shared.......mine was about the same when I received the photos from Audi post dismantling.....
  4. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #94
    Feb 2009
    Ireland
    6 Post(s)
    I wonder if the blockage is more due to the crystallization or the soot. The soot, by feel, was very light, fluff like, urea deposits were fairly hard. There are few adblue additives (additives on additives the world we live in) that claim they prevent forming hard urea deposits, e.g. Forte, Wynns, Total, but they seem to be mainly designed for trucks, business, not consumer. I've just had adblue injector cleaned and only few hundreds km from then I already see white stuff forming on the nozzle, but it's more powder like rather than hard depositing.
  5. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #95
    131 Post(s)
    1974 Post(s)
    It is the urea deposits, they set like cement; apparently it is a huge pain with big commercial Diesels.
  6. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #96
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    And my keks, according to the missus.
  7. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #97
    131 Post(s)
    1974 Post(s)
    Quote Originally Posted by Whippy53 View Post
    eeewww yuk
  8. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #98
    Feb 2009
    Ireland
    6 Post(s)
    So after about 400km after the egr cooler cleaning the fault is not returning, thanks to this post!
    I watched a couple of youtube videos on this job and it brings memories of pain and some people take it way further than I had to - what a horrible design and new cars in general.
  9. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    #99
    Nov 2022
    Poland, Radom
    Hello everyone!
    P2002 on mine 2015 CNHA A6 brought me here.
    This is my first post here so let me introduce myself 😊. I'm Christopher, live in Poland and I've been using my Audi daily since 2017 to drive myself to work about 60 miles back and forth couple times a week with a highway (60-80mph constant speeds)... No major issues with the car so far (150k miles odo) but it started showing this P2002 error some time ago. No other symptoms so after doing some research I'm pretty sure it's all about this damn cooler.
    I already bought some excellent condition used one (20k miles) and it was really a bargain (20£) but the labour at dealers gave me a headache (1200£, thought I'm pretty sure they quoted me that amount only to get rid of me)... Anyway - I decided to do it myself. I'm pretty sure I have all necessary stuff (jack and stands, endoscopic camera, spline torx bits, hose clamp tool etc) and skills (two hands LOL) to manage it but still I have some questions (especially to nordic_b as he's done that by himself).
    Is it necessary to undo DPF filter while I'm not intending to clean the thing?
    Exhaust pipe... Is it necessary to take it away or can I just undo it from DPF filter and move away a little?
    The cooler itself if fastened to DPF with couple of bolts and with a bolt and bracket from the back. Is it possible to reach the lower bolt holding this bracket to the engine from the top?
    Any other tips would be highly appreciated. Thanks!
  10. Re: 2.0 TDi Ultra CNHA EGR and cooler removal and cleaning
    131 Post(s)
    1974 Post(s)
    I did the first service on a 10k mile 2022 A4 yesterday, I was horrified at the complexity of the exhaust after treatment system... insane. DTNA code engine "EU6 AP" standard, pre cat with AdBlue injector, DPF and then a second cat with AdBlue injector so if the pre cat injector fails and blocks all three units that is £7000 in major parts alone, effing madness!
  1. Question Heater Matrix Removal and cleaning
    By barachello in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-11-2017, 07:57 PM
  2. Replies: 19
    Last Post: 19-07-2016, 11:51 AM
  3. Question EGR Removal for cleaning/replacement
    By Ant7t5 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-11-2013, 08:26 PM
  4. Oil cooler removal
    By millinb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-06-2009, 03:37 PM
  5. Starter motor on MK4 TDI REMOVAL and CLEANING OR REPLACING(HOW TO?)
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 09:46 PM
