Thread: Audi 80 leak
  1. Audi 80 leak
    We have a leak into front footwells on our Audi 80 avant any ideas? Is this a blocked drain tube? If so how can I unblock please?
  2. Re: Audi 80 leak
    Leaking Heater matrix if your losing coolant
  3. Re: Audi 80 leak
    check the bulk head mate most audis have a drian around the front bulk..if it becomes blocked (leaves etc etc ) the you will get a build up of water that may drain into the foot wells ..i,ll check it out 2 moz and give you some more ideas..
    dont go drowning in the mean time
  4. Re: Audi 80 leak
    thanks for advise I really need to get this sorted
  5. Re: Audi 80 leak
    You should find drain holes at either end of the bulkhead, at the front. Not sure about the passenger side, but my 1993 80 also has one on the drivers side that drains into the wing. I discovered a swimming pool in mine recently and found that the grommet for the bonnet cable had pulled through, creating an extra drain hole into the footwell!
  1. Audi A4 Avant 1.9 Water Leak Passenger Side Footwell
    By Water Boy in forum Audi A4 - Archive Topics
    Last Post: 13-11-2007, 12:09 AM
  2. Oil leak
    By shottdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2007, 08:59 PM
  3. Audi 80 water leak
    By stillgrinning in forum 80 - 90
    Last Post: 26-07-2007, 04:26 PM
  4. audi coupe leak
    By 4ring in forum Chat - Completely Off Topic
    Last Post: 01-03-2007, 03:38 PM
