Thread: A3 1.6tdi (2010) overheating coolant warning light
Results 11 to 20 of 36
  1. Re: A3 1.6tdi (2010) overheating coolant warning light
    Nov 2019
    Sheffield
    Cheers. Will have think about getting it done.
  2. Re: A3 1.6tdi (2010) overheating coolant warning light
    Near Blackpool
    48 Post(s)
    Running heater on full technically cools your engine a little as some of the coolant goes through the heater matrix. So turning it off is why your car suddenly overheats. Keep it on. Let us know how you get on.
  3. Re: A3 1.6tdi (2010) overheating coolant warning light
    Sep 2008
    Quote Originally Posted by jonathanfenton View Post
    Yes, I had a similar problem with my old A3 and managed to get home by opening the windows and putting the fans and temperature up to maximum; I didn't really want to stop on the Heathrow perimeter road having done it once when the clutch went (police are there very fast!).
  4. Re: A3 1.6tdi (2010) overheating coolant warning light
    Nov 2019
    Sheffield
    No, it's the other way round, the car overheats when heater is on full, the car cools when I turned it off and open the window.
  5. Re: A3 1.6tdi (2010) overheating coolant warning light
    134 Post(s)
    2007 Post(s)
    That doesn’t make sense, does it lose any water by blowing it out of the expansion tank?
  6. Re: A3 1.6tdi (2010) overheating coolant warning light
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Quote Originally Posted by Jblakes84 View Post
    Is there a fuel powered auxiliary heater that could be turning on when it mistakenly thinks coolant is cold but heat is needed in cabin?
    My other thought is some form of changeover valve that is trying to take pumped water through heater matrix which is blocked. Turning heater off takes water through open path that bypasses heater. No idea if such valve is installed though.
  7. Re: A3 1.6tdi (2010) overheating coolant warning light
    #17
    Near Blackpool
    48 Post(s)
    Quote Originally Posted by VAG-Abound View Post
    Only “valve” would be the thermostat.
  8. Re: A3 1.6tdi (2010) overheating coolant warning light
    #18
    134 Post(s)
    2007 Post(s)
    They have a supplementary electric water pump which is prone to failure, that could be influencing it but I would still like to know if it is losing coolant out of the tank cap.
  9. Re: A3 1.6tdi (2010) overheating coolant warning light
    #19
    Nov 2019
    Sheffield
    Cheers all for replies, no the coolant level hasn't moved, so not a leak anywhere.
    How do I tell if I have an auxiliary heater, as I've no clue what one is.
    Regards James
  10. Re: A3 1.6tdi (2010) overheating coolant warning light
    #20
    134 Post(s)
    2007 Post(s)
    You have an electric one not a Diesel type so it is irrelevant. When the light comes on, does the gauge reading increase or just stay on 90?
  1. Please Help Overheating warning light
    By eastmidsdude in forum Golf MK7 - 2013 - 2019
    Last Post: 05-04-2019, 02:00 PM
  2. Question 2010 VW bulb warning light issue
    By CsidgeVW in forum Chat - Anything with wheels
    Last Post: 10-04-2018, 08:32 PM
  3. Engine Fault Warning Light - 1.6TDi
    By Bob_S in forum Golf MK6 - 2009 - 2013
    Last Post: 07-05-2017, 08:11 AM
  4. Egr touran 1.6tdi cr 2010
    By Runel77 in forum Touran - Sharan - Caravelle
    Last Post: 16-05-2016, 09:15 AM
  5. 2010 passat fault warning light
    By Castrol1450 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-07-2013, 06:16 AM
