Thread: 225 fuel level sensor
  1. 225 fuel level sensor
    May 2018
    Ayrshire
    Newbie here so be gentle.......
    My fuel gauge always reads full it drops to empty when the ignition is switched off. This rules out the dash pod apparently.
    I’ve been told that it is the fuel level sensor in the tank but I have had conflicting advice (no surprise there&#128580
    My question is would I be better running the tank dry and trying to clean/free the float/sensor? Or would I be better to just replace the fuel pump?
  2. Re: 225 fuel level sensor
    2007 Post(s)
    We have never replaced a TT1 fuel level sensor but have replaced more dashes than I can remember. A diagnostic output test should proved more info as would disconnecting the sensor BUT doing that will generate a fault code so a fault code read before and after as a ghost code could confuse someone later.
  1. Faulty fuel level sensor ?
    By niedzial1983 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-10-2016, 11:02 PM
  2. Fuel level sensor
    By rob1976 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2013, 11:01 PM
  3. Fuel Level Sensor Error
    By swool in forum VCDS - General Questions
    Last Post: 10-12-2010, 11:19 AM
  4. 01441 low fuel level sensor
    By philfingers in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-03-2010, 12:09 AM
  5. Fuel level sensor fault?
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2008, 11:41 PM
