Thread: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
Results 1 to 10 of 12
  1. Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    May 2010
    Colchester
    Hi all - I need your help!
    I keep being told different things about how often I should change the Timing Belt (and Water Pump) on my 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    Different garages (Main Dealer and Independents) tell me different things, such as it is every 5 years/60k miles, or every 4 years/80k miles and even every 5 years/140k miles!
    What is the right answer?! Pleeeeeease !
    Thank you everyone and all the best,
    Tony.
  2. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    May 2017
    Wrexham, N.Wales
    Morning Tony,
    Most garages used to recommend every 60k/70k.
    There isn't really a right or wrong answer but if you're worried it might fail get it changed just for piece of mind.
    Paul
    Sent from my H8216 using Tapatalk
  3. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    2014 Post(s)
    The VAG UK advice for a diesel it is 4 years up until 2009 and then 5 years but this is not in the VW schedule, it was suggested by VAG UK many years ago due to excessive in schedule failures, as far as I have seen they did not list a distance. The official VAG workshop system Elsawin listing for the BKD (all PD TDI in fact) increased in 2007 from 120000 km to 150000 Km (93206 miles) for the belt and from 240000 km to 300000 km (186412 miles) for the tensioner with no mention of the water pump and no time interval so that is the official VAG Germany listing, anyone prepared to follow that advice must have big balls or not care about money... Our view is the 4 and 5 years advice and 70k miles, whichever comes first and do the belt, tensioner and water pump and following this none of our customers has every experienced a failure in decades.
  4. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    May 2010
    Colchester
    Hi Crasher.
    Thank you for such an informative reply!
    You're right, you'd need big balls to trust those figures. I wouldn't want to risk those mileages and I'm not mechanically minded!
    As in my reply to Paul, my timing belt was last done 3.5 years ago and 65k... so I *might* be ok to leave it another few miles/months to give me a chance to save up!
    Tony.
  5. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    May 2010
    Colchester
    Hi Paul.
    Thank you for getting back to me so quickly.
    I've just checked and my timing belt was last done 3.5 years ago and 65k miles ago...
    I'm not mechanically minded, so I don't know whether to worry or not, but based on your figures of 60k/70k, it looks like it is time to get it done.
    My car is now on 160k and the turbo has started to overboost and it needs a service, so I need to find a recon turbo from somewhere and get it done at the same time as the service. I was just hoping not to do the timing belt too as it's going to be an expensive month with the turbo, especially so soon after Christmas
    Tony.
  6. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    How long ago (in time and miles) was it last done? That'll help people tell you if it's overdue or not.
    To me it partly depends on how long you expect to keep driving the car, and its ongoing value / costs (due to age, other things coming up like CV joins, gearbox noises, etc). If it's about due a change and you expect to be driving it 12k/year for another couple of years you'd be wise to get it done in that period, so do it now and get more worry free miles from the change .
    On our somewhat car park damaged 2003 car that only does ~4k/year I let it slip longer than I would normally because I was thinking of getting rid of it and took the chance each time I went out even thought it was ~20% past limits on time and distance for change. But then decided to keep it running so had the belt & pump done ASAP.
  7. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    May 2010
    Colchester
    Hi Vag-Abound.
    Thank you for your reply and, you're right, I should've added when it was last done.
    I've just checked and my Timing Belt and Water Pump were done:
    May 2012 @ 35k miles;
    March 2016 @ 95k miles.
    My car is now on 160k miles and the belt was last done 3.5 years/65k miles ago. I do between 12k/15k miles a year.
    The turbo is over-boosting, the DMF has been shaking for a few years and there is rust just starting to come up on the N/S front wing and possibly the sill. Adding in the cost of the Timing Belt, I did think about selling the car, buuuut, it has been in my Family since new, I've owned it since it was 3 years old/20k miles and it has been so reliable.
    I don't need anything flash and my 9 year old Daughter loves it (!) and I figured that I could buy another car for £Xk and still need to do timing belts etc., not to mention the risk of buying a lemon... so I figured it was better to get a recon turbo, wait until the DMF is really bad, patch up the wing when it gets really bad and just keep driving it until it dies.
    Based on that, I had better get it done in the next few months.
    Tony.
  8. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Sounds similar to our 2003 Touran, which I thoroughly enjoy driving once I'm off of our cul de sac with the noisy DMF . I think I'll just about be able to replace that if I decide it's needed, but it'll be a bit of a hassle with getting gear box out with no post lift...
    Limping turbo is a pain - less fun driving and can seem a real danger if it happens on long uphil motorway sections. I did the one on our BKD in a spacious workshop on ramps. No specialist tools, just somewhere wind, rain and sunlight / dazzle free and able to lock everything up while I spent a steady weekend doing it. Not a particulalry difficult job as long as you're reasonably dexterous, can wriggle around under car quite easily, and have a decent selection of long / short ratchet wrenches, spline / torx / hex bits, etc.
    I got a new Melett from Darkside. Seemed like good value compared with someone like Midland sending a refurb OEM, and needing the original back. If I was doing it again I'd get the original off and see if a good clean up looks likely to get it running again. Get a replacement on standby - fit if needed or send it back if you decide to clean up the original. If you can manage without car while replacement arrives once damage is discovered (ours looked like something had gone through the exhaust vanes - but I don't think that was causing the overboost!) so much the better to avoid double shipping plus any restock fee.
    Rust is a pain. I recall friend's first cars 70s / 80s cars having it, but never had to worry about it much myself. When I do I try to get panels and crevices opened up to get to the root of it, which has worked well. Good luck .
  9. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    May 2010
    Colchester
    Hi VAG-Abound.
    You know your stuff around a car, but I don't. I have to YouTube to change a Headlight bulb Ok, maybe I'm not that bad, but you get the idea! I wouldn't know how to do all the things you did on your car, plus I have no tools whatsoever, so I'm going to have to get someone else to do it for me (I'd love to go to night school and learn some basic mechanics, but I work rolling shifts, so that'll never work out).
    I kept reading about using things like Mr Muscle, Wynn's Turbo Cleaner etc., but I think they are only ever temporary 'fixes', so I'll go with replacing the turbo.
    What made you think that a new turbo was better value than a recon one? I thought recon ones (from proper companies like Essex Turbos and Turbo Technics) were meant to be like brand new, due to all the internals being replaced?
    Cheers,
    Tony.
  10. Re: Timing Belt interval on 2007 Mk5 Golf 2.0L 140Bhp Diesel BKD/PD Engine.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    It was a somewhat convoluted plan to put new turbo on 1 car, clean up the removed one and put it on a second car, and then have the removed one from the 2nd car left over. I didn't expect to getall that done in the timespan for sending a turbo back as part of the recon deal.
    As it turned out, developing noise on car 2 was DMF not turbo and an intermittent limp on car 2 has also resolved with some spirited driving and excercising acctuator fully with vacuum pump.
    So a simple recon swap may have worked out, but looking at damage to the one I have it would have been high rather than low end of final refurb fee and if I now manage to sell it as is I won't be far off of that cost afterall.
  1. Timing belt interval?
    By jmurray01 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-04-2019, 08:53 PM
  2. Timing Belt Interval
    By phy7tes in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-11-2016, 08:21 PM
  3. Please Help Timing belt interval's
    By JON35Y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2012, 05:24 PM
  4. A4 B7 Timing Belt Interval
    By whammer007 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-04-2011, 07:14 AM
  5. Timing belt interval?
    By mattiustherebel in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2010, 10:49 PM
