Thread: B8 Avant Quattro Diagnoses
  1. B8 Avant Quattro Diagnoses
    Ardfern
    8 Post(s)
    On my 2011 model A4 Avant Quattro I have two symptoms which I hope someone here can help me to diagnose.
    1. As I brake gently towards a standstill, at the last moment the brake pedal rises slightly and unless I also raise my foot, the braking becomes heavier bringing the car to a more sudden stop than planned. Otherwise the brakes are good and do not judder to any significant extent. The front discs and pads were replaced within the last 20,000 miles and the rear discs and pads were replaced within the last 30,000 miles.
    Prior to this symptom appearing, there was an unusual glitch: while driving slowly in town the car gave a hiccup and the handbrake warning light came on. When I stopped after a short drive, the engine would not switch off until I pressed and held the ignition key for several seconds. When I restarted the engine and drove on, the warning light had extinguished and has not reappeared and the only brake symptom is that which I have described above.
    2.After the glitch mentioned above, there is a jerkiness on overrun which may in some way be related.
    Here is a scan log taken after the glitch:
    Tuesday,24,December,2019,13:59:09:60719
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 19.6.2.0 (x64)
    Data version: 20190930 DS308.0
    Ross-Tech: Home
    VIN: WAUZZZ8K0CA045541 License Plate: YR61ETE
    Mileage: 309870km-192544mi Repair Order: 24/12/19
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 56 5F 62 72
    VIN: WAUZZZ8K0CA045541 Mileage: 309870km-192544miles
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CAHA) Labels:. 03L-906-019-CAG.clb
    Part No SW: 03L 906 022 RM HW: 03L 906 019 AL
    Component: R4 2,0L EDC H35 8422
    Revision: 25H35---
    Coding: 12194012242701080000
    Shop #: WSC 06334 000 00000
    ASAM Dataset: EV_ECM20TDI03L906022RM A02005
    ROD: EV_ECM20TDI03L906022NP.rod
    VCID: 010289C590E42547A8-8054
    6 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [040] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 308794 km
    Date: 2019.12.10
    Time: 10:49:05
    Engine speed: 1520.00 /min
    Normed load value: 20.0 %
    Vehicle speed: 41 km/h
    Coolant temperature: 79 °C
    Intake air temperature: 17 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 14.100 V
    Unlearning counter according OBD: 29
    Cruise Control System (CCS): switch position-Bits 0-7: 129
    CCS status-Bits 0-7: 40
    Cr Ctl st Sh Off Irv Lst-Bits 0-7: 255
    Cr Ctl st Sh Off Rv Lst-Bits 0-7: 255
    Cr Ctl v Des Dspl: 0.00 km/h
    Sig Reset Env x Id-Bits 0-7: 0
    Cr Ctl st Shut Offirev-Bits 0-7: 0
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [040] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 308794 km
    Date: 2019.12.10
    Time: 10:49:05
    Engine speed: 1573.00 /min
    Normed load value: 8.6 %
    Voltage terminal 30: 14.200 V
    7144 - Please Check DTC Memory in CAN Gateway (J533)
    U1008 00 [096] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Intermittent - Not Confirmed - Tested Since Memory Clear
    5380 - Valve for Air Filter Bypass Flap (N275)
    P1016 00 [047] - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 14
    Mileage: 284831 km
    Date: 2018.10.27
    Time: 12:25:24
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 4 °C
    Intake air temperature: 7 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.960 V
    Unlearning counter according OBD: 40
    Air mass: specified value: 883.0 mg/stroke
    Coolant temperature at radiator outlet: actual value: 4.8 °C
    Ct T t Diff Radiator: -273.1 °C
    Ambient temperature: 4.5 °C
    Coolant fan 2: activation: 0.00 %
    Coolant fan 1: activation: 10.20 %
    Fuel temperature: 6.0 °C
    5382 - Valve for Air Filter Bypass Flap (N275)
    P1015 00 [032] - Short to Ground
    4987 - Cylinder 4 Glow Plug Circuit (Q13)
    P0674 00 [047] - Electrical Fault
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 284831 km
    Date: 2018.10.27
    Time: 12:26:32
    Voltage terminal 30: 11.880 V
    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
    Electric auxiliary heater: shut-off conditions-Bits 0-7: 28
    Electric auxiliary heater: relay activation-Bits 0-7: 0
    Preheat time: 2500 ms
    Glow status-Bits 0-7: 0
    Ambient temperature: 4.0 °C
    Fuel temperature: 5.9 °C
    Eng Da ti Eng Off CAN: 0 s
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
    Part No SW: 8K0 907 379 BG HW: 8K0 907 379 BG
    Component: ESP8 quattro H04 0020
    Revision: -------- Serial number: --------------
    Coding: 180504
    VCID: 7F060F3DEE1053B7DE-802A
    3 Faults Found:
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    008 - Implausible Signal - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 308794 km
    Time Indication: 0
    Date: 2019.12.10
    Time: 10:49:04
    Freeze Frame:
    Hex Value: 0x1F00
    Hex Value: 0x4086
    Hex Value: 0x1F08
    Hex Value: 0x36B4
    Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 308794 km
    Time Indication: 0
    Date: 2019.12.10
    Time: 10:49:05
    Freeze Frame:
    Hex Value: 0x2800
    Hex Value: 0x4386
    Hex Value: 0x1F2E
    Hex Value: 0x02B4
    Hex Value: 0x00FF
    003 - Mechanical Failure - Intermittent - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 308794 km
    Time Indication: 0
    Date: 2019.12.10
    Time: 10:49:04
    Freeze Frame:
    Hex Value: 0x1F00
    Hex Value: 0x4086
    Hex Value: 0x1F08
    Hex Value: 0x36B4
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CN HW: 8K0 907 064 CN
    Component: BCM2 2.0 H05 0435
    Revision: 00002001
    Coding: 033200
    Shop #: WSC 06335 000 00000
    VCID: 7EF8F239E91A5ABFD5-802A
    Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
    Component: FBSAUDIB8 IDG H60 0072
    Serial number: 0811000127098017
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    Serial number: 2311000166502004
    No fault code found.
    Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
    Part No SW: 8T2 820 043 AF HW: 8T2 820 043 AF
    Component: KLIMA 3 ZONEN H08 0182
    Revision: D0000000 Serial number: 01090820110307
    Coding: 34340000
    Shop #: WSC 26220 001 1048576
    VCID: 76E8EA19C12A12FF8D-8022
    1 Fault Found:
    01020 - Water Pump (V36)
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 4
    Fault Frequency: 139
    Reset counter: 44
    Mileage: 295259 km
    Time Indication: 0
    Date: 2019.03.06
    Time: 16:03:33
    Freeze Frame:
    Voltage: 14.00 V
    Temperature: 81.0°C
    Current: 0.025 A
    Voltage: 5.00 V
    Voltage: 3.00 V
    Bin. Bits: 00000001
    RPM: 1280 /min
    Load: 0.0 %
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
    Component: BCM1 1.0 H30 0392
    Revision: 06030001 Serial number: 00000001176745
    Coding: 6900C0B10034A7010001000000005F5F001D06080600014100 0000
    Shop #: WSC 06335 123 12345
    VCID: 3776271D86A0ABF756-8062
    Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 120811 H06 0070
    Serial number: SWF11080125434
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Serial number: 11612086
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000000708110062
    Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
    Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
    Component: PARKHILFE 8K H01 0081
    Revision: 11001001 Serial number: 12501122201008
    Coding: 100203
    VCID: 78F4E421CB3E648F9F-802C
    Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
    Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
    Component: AirbagVW-AU10 H44 0610
    Serial number: 003JMD0FAY0U
    Coding: 30533435363030303030554A3052384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
    VCID: 46885AD9F94AC27FDD-8012
    Crash sensor for side airbag: driver side:
    Serial number: 6334MSME625511687
    Crash sensor for side airbag: front passenger side:
    Serial number: 6344MSME62452D4CM
    Crash sensor for side airbag: rear: driver side:
    Serial number: 6352QSME785C365E.
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 6362QSME195D2F78
    Crash sensor for front airbag: driver side:
    Serial number: 63732SME544F4E4EK
    Crash sensor for front airbag: front passenger side:
    Serial number: 63832SME544F036E8
    Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
    Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
    Component: Lenks.Modul H07 0156
    Revision: 00000000 Serial number: 20110818000351
    Coding: 000017
    VCID: 499251E5E0542D0730-801C
    Component: E221 - MFL H02 0010
    1 Fault Found:
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 33
    Mileage: 308794 km
    Time Indication: 0
    Date: 2019.12.10
    Time: 10:49:05
    Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 981 D HW: 8K0 920 981 D
    Component: KOMBIINSTR. H70 0402
    Revision: 00000000 Serial number: KI271AG8C
    Coding: 2F05110002002600010000
    VCID: 346C101197D640EF73-8060
    1 Fault Found:
    00003 - Control Module
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 308927 km
    Time Indication: 0
    Date: 2019.12.11
    Time: 17:10:08
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
    Component: GW-BEM 4CAN-M H09 0117
    Revision: EC000056 Serial number: 5600E11803805C
    Coding: 00CF07
    VCID: 030E83CD82F83757BA-8056
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0140
    Serial number: 00000000005650252795
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    Serial number: 11224000217011200181
    Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
    Part No SW: 8K0 959 793 N HW: 8K0 959 793 N
    Component: TSG FA H12 0357
    Revision: Serial number: 0000011685779
    Coding: 011002204001410001
    VCID: 4B9E6BEDEA283F1702-801E
    Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0155769401
    Coding: 013B062220B904408020023680000000
    Subsystem 1 - Part No: 8K0 951 177
    Component: DWA-Sensor H02 0040
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
    Part No SW: 8K0 959 792 N HW: 8K0 959 792 N
    Component: TSG BF H12 0357
    Revision: Serial number: 0000011369488
    VCID: 4A906EE9E552261F39-801E
    1 Fault Found:
    00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 4
    Mileage: 299542 km
    Time Indication: 0
    Date: 2019.04.23
    Time: 09:45:16
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 20000000080881
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 308794 km
    Time Indication: 0
    Date: 2019.12.10
    Time: 10:49:05
    Freeze Frame:
    Voltage: 14.70 V
    Count: 62
    Speed: 40.0 km/h
    Hex Value: 0x0260
    Hex Value: 0x0004
    Hex Value: 0x0101
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 056 H HW: 4G0 035 056
    Component: Radio U STD H52 0134
    Revision: AB001007 Serial number: 469H90B7787901
    Coding: 010003020100000001
    VCID: 2648FA59510A227FFD-8072
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8T2 035 652 N HW: 8T2 035 652 D
    Component: B-BN-EU H61 B-BN-EU H61 01910191
    Revision: -------- Serial number: 305H-0B7529083
    Coding: 01010101000681ED01000B0E000000030000
    VCID: 418249C5D864E547E8-8014
    Subsystem 1 - Part No: 4G0 060 884 AE
    Component: EUR 2019 2802
    Subsystem 2 - Part No: 8T0 919 604
    Component: DU6 Basic
    Subsystem 3 - Part No: 8T0 919 609
    Component: E0380 Bedient
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
    Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
    Component: TSG HL H11 0357
    Revision: Serial number: 0000011712908
    Coding: 010002204001210001
    VCID: 458A5DD5CC4CC967D4-8010
    Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
    Component: TSG HR H11 0357
    Revision: Serial number: 0000011712941
    End-------------------------(Elapsed Time: 03:15)--------------------------
    I removed the rear offside wheel and disconnected the ABS sensor cable and the plug and socket looked fine, so I reconnected the cable.
    A scan taken today after having deleted the fault codes and driven the car shows no brake or ABS fault codes.
    Has anybody a reasonable suggestion as to what has happened or what I should check next?
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  2. Re: B8 Avant Quattro Diagnoses
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Your fault log shows "
    008 - Implausible Signal - Intermittent - MIL ON "
    It reports the fault as INTERMITTENT, so I would guess that the signal from that sensor is just on the edge of failing.
    When the wheel is turning slowly ( as you are coming to a stop ) the signal is at its lowest, so intermittently triggering this code.
    This will activate the ABS as it will see it as the wheel locking giving you a weird feeling in the brake pedal & sharp stop.
    It could be the sensor or the ABS ring.
  3. Re: B8 Avant Quattro Diagnoses
    Ardfern
    8 Post(s)
    Thanks. That accords with my guess as to what may be wrong and causing the brake anomaly. The jerky running on overrun does not seem to be related though.
  1. Help with ESP Light - diagnoses required
    By fireblader in forum VCDS - Help Requests
    Last Post: 30-06-2013, 03:53 PM
  2. Which A6 Quattro Avant of these 3?
    By doggydoo in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 26-04-2013, 06:44 PM
  3. Question A4 1.9 TDi Avant Quattro
    By Craigk2809 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-05-2012, 09:09 PM
  4. 99 A6 2.5 tdi Quattro Avant -what BHP?
    By Steviegeeza in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-11-2010, 11:43 AM
  5. Non Quattro to Quattro 80 avant?
    By Ozaudi80 in forum 80 - 90
    Last Post: 27-10-2008, 03:42 PM
