Thread: Dpf cleaning
  1. Dpf cleaning
    Aug 2019
    IE
    I'm going to use the wurth dpf cleaning spray on the a5 2.7tdi .The question is what port /hole does in go into ,there is two ,any help ?
    Sent from my SM-G960F using Tapatalk
  2. Re: Dpf cleaning
    May 2012
    Everywhere
    308 Post(s)
    Why does it need cleaning ?
  3. Re: Dpf cleaning
    134 Post(s)
    2011 Post(s)
    Take out the Lambda sensor on top of the DPF. I strongly recommend you do not take out the EGT sensor, they have a nasty habit of Galling and ruining both the sensor and the DPF’s thread, which can be... galling . When you reinstall the Lambda sensor you should apply a thin wipe of anti seize paste (Copper based is not ideal) and we use Buy Alu paste AL 1100 online
    We tried it on our Passat loan car and so far so good, you will need to do a proper forced regeneration after, using a diagnostic system.
  4. Re: Dpf cleaning
    Aug 2019
    IE
    That is the one on the right ?
  5. Re: Dpf cleaning
    134 Post(s)
    2011 Post(s)
    Yes, the lambda sensor, 22mm across flats.
  1. Please Help Cleaning the HUD
    By boxsterman in forum A7 - S7
    Last Post: 19-09-2017, 10:53 AM
  2. Cleaning an EGR on the 2.5D?
    By Padwick in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-02-2010, 04:17 AM
  3. Cleaning the MAF
    By ddave05 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2009, 03:45 PM
  4. mk4 GTI T cleaning TB
    By mk07 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-01-2009, 06:20 PM
  5. Not really a car, but hey, its still cleaning!
    By Eshrules in forum Show 'n' Shine - Post your efforts here
    Last Post: 22-03-2008, 09:59 PM
