Thread: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
Results 1 to 8 of 8
  1. Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    Dec 2019
    Redditch
    Hi All
    I am a novice at posting so hopefully this works ?.
    My wife has a mk6 golf which is the love of her life.. Very recently the alarm started to go off which was promptly silenced with a lock and unlock via the key fob. Now I have lost power to the left side of the car, this includes door mirror, windows and also very annoyingly the doors on the left side of the car will not unlock.
    I have reviewed the look in the drivers door and cannot see any broken wires. In frustration I removed the battery and recharged, my wife only does short journeys and I thought battery terminal voltage may be an issue. After 8 hours charging the battery was done and promptly reinstalled on the car, hey presto the left side of the car came alive, phew....
    Morning came around and a new battery was bought as some of the cells on the old battery looked to be short of acid (sealed battery). Installed on the car and the left side of the car is once again dead.
    Annoyingly I also have an airbag fault light now, I guess this is because I removed the drivers door loom from its connection to the Body Control Module.
    I have spoken to the local VW garage and unfortunately they are not much use, suggesting they would have to use brute force to open the doors...not keen on that idea.
    So in summary has anybody out there come across a similar problem and is there a fix you could kindly suggest ?
    I am in the process on by a scan tool so I can read any diagnostic codes set and also hopefully clear the air bag fault light.
    Thank You
    NIgelMark6 !
  2. Re: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Have you had any leaks that might have damaged the control module?
  3. Re: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    131 Post(s)
    1978 Post(s)
    I had this on a Golf 5 a number of years ago, the left doors suddenly went dead, the rear door is operated via the front door control unit (the winder motor escentially which is operated by the BCM, the Body Control Module, the diagnostic system VCDS was not much help except it showed no comms with the front door. On the Golf 6 the BCM is the same as the five. Unfortunately the BCM is behind the glovebox and you can only get the glovebox out, with the door open... I managed to do this by running a door lock harness from the drivers door to the passengers door and then, after a HUGE struggle due to the Golf 5's insane door design, managed to plug it in to the passengers motor, operated the key and it opened. I removed the glovebox and fitted a new BCM, coded it in and everything worked... except I could not get the remotes to program in. I refitted the old BCM to check they workes and they but now so did the left door and it has been like that now for years. I sent the new BCM back to TPS with a strong note of annoyance.
  4. Re: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    Dec 2019
    Redditch
    Hi Car is bone dry. So at a loss why when I fitted the battery (fully charged) the doors unlocked (briefly) Thanks for the suggestion
  5. Re: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    Dec 2019
    Redditch
    Many thanks for the info. Getting the door card off when the door is locked is a bit of a trial. Is the BCM on the passenger side or the drivers side. I have a sneaky feeling the BCM on my golf is on the drivers side unerneath the area by the steering wheel. I will have a look when it finally stops raining !
    Thank You
  6. Re: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    We've recently had similar trouble on our Touran. In our case it was a mechanical weakness in the lock making passenger door unopenable, so repeated excersising of remote locking with suitable vibration from banging door did eventually get it open for me to work on. As yours is an electrical failure that's unlikely to work...
    It needed to be open for non destructive repair as the door card has screws and an edges that "flow" into the cabin shape, so impossible to remove with door closed. Not sure if Golf is same. As I was battling with various parts in the door after getting it open I was idly wondering how the other multiple reports in the last couple of weeks would get on if door couldn't be opened.
    As "least worse" options, compared with destruction of door metal, I came up with:
    1. Use ~80mm hole saw to make holes in card over electrical connectors if they are suspect. Repeat on other door for aesthetic purposes . Hopefully applying 12V to correct pins (perhaps identifiable by playing with working door and a multimeter?) can activate unlocking. With a bit of luck and suitable colour mastic or painted push-in lid the hole could be quite well hidden.
    2. There's a Door Woes thread about how I found the deadlocking works, and being able to flick the right component should then get door handle working for dismantling and repair. Unfortunately many cars have a solid / unperforated "carrier" panel between the door card and outer door workings with window lifter, etc on it. So unless door card and then this carrier can be removed it's impossible to reach lock mechanism from inside for manual flicking of components to open door. Although our door mechanism has some plastic shrouding for weather or thief proofing I think you could get past this if the window was smashed () and removed, plus the strip along top of door that gives it some weather seal. That would give about an inch wide gap to peer into with a torch and tools.
    Hopefully it won't come to that though - good luck.
    [EDIT: Just had an afterthought that assuming window lifter is working (maybe not if BCM is bust..) then with correct drilling of door card it'd be possible to undo the clamps that secure glass to carrier from inside. Then electrically or manually lifting it, holding it in closed position while mechanism is lowered and finally manually lowering glass into door by hand may allow it to be leaned past carrier so it sits on bottom of door giving access through top edge]
  7. Re: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    While wondering if Mk6 had the removable outer door skin which could have helped I found this showing how the internal wiring is laid out: Front Door Trim Removal – Volkswagen MK6 Golf – AutoInstruct.
    This link gives you a nice big, zoomable view of the plug into the latch unit: https://mk0autoinstruct25ass.kinstac...6/LJS_4370.jpg. Hopefully access to the 7 wires somewhere along its length will let you feed what is needed to release the deadlock - maybe as simple as bringing across from other door.
    Found some wiring diagrams. They label white wire (position 5 on connector) as controlling the SAFELOCK motor (which disables inside handle), yellow (7) for the motor for other locking (when inside handle pull will release door) and violet (6) as common / earth. But looks like there is a bit of mislabeling going on as that picture shows white, yellow, violet as 5, 6, 7. Bit of checking on your driver door to see may be in order.
    Wiring diagram for the other side shows position 1, 2, 3 as violet, yellow, white - which would match picture order although all reversed IYSWIM . White is again SAFELOCK motor into violet. Reading how SAFELOCK works if you can get that motor to move then a tug on inside handle should open door.
  8. Re: Golf Mark 6 - Passenger Door Rear and Front Not Unlocking from Inside or Outside.
    Dec 2019
    Redditch
    Hello
    Thank you for the detailed reply.
    I have just invested in a ANCEL VD500 Diagnostic device. Plugged in and cleared the annoying AirBag Fault I had created by removing fuses etc whilst trying to diagnose issue with left hand aside door locks and Window lift.
    So fault codes resident are.
    0133
    0132
    01333 - Door Control Module Rear Left (J388)
    01333 - Door Control Module Rear Left (J388): Defective
    Possible Causes
    • Fuse(s) faulty
    • Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388) faulty
    • Door Control Module Rear Left (J388) faulty
    Possible Solutions
    • Check Fuse(s)
    • Check Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388)
    • Check/Replace Door Control Module Rear Left (J388)
    01332 is the sane for the rear passenger side door.
    Annoyingly the window lift is not working either.
    Very Oddly
    I replaced the battery - hard reset to the car and hey presto the left hand side came alive, however by morning it was dead again. I am not sure what this tells me other than possibly not a wiring fault, more a module issue, either with Voltage levels or ??
    The info on removing the inner door card was very useful - I have done this on the drivers side and its a pain.
    The big trial now is removing the door card whilst the door is closed..
    Thank you again for your detailed help.
  1. Solved Passat b5.5 variant rear door not unlocking or opening from inside or out!
    By king.lion in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2016, 05:35 PM
  2. Please Help Front passenger door not unlocking
    By witblitz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-08-2014, 12:54 PM
  3. Front Passenger Door will not open using inside handle
    By silentbazz in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2008, 01:38 PM
  4. Rear passenger left door not locking/unlocking.
    By desgreen in forum Passat - Archive Topics
    Last Post: 21-10-2006, 06:43 AM
  5. Rear passenger left door not locking/unlocking.
    Last Post: 26-07-2006, 06:41 PM
