Thread: A6 1.8T Oil consumption
Results 1 to 10 of 13
  1. A6 1.8T Oil consumption
    Jun 2007
    How much oil do you use in your 1.8T engine and what mileage has it done ?? Regards Peter
  2. Re: A6 1.8T Oil consumption
    Jun 2007
    Anyone. Regards Peter
  3. Re: A6 1.8T Oil consumption
    135 Post(s)
    2038 Post(s)
    Nothing in mine over 2000 miles but that’s with a brand new engine and turbo. My customers report virtually zero unless there is a problem. What are you using litres per 1000 miles?
  4. Re: A6 1.8T Oil consumption
    Jun 2007
    A, A
    17,000 Miles since last service and the dip stick level has never moved.
    Just another B7 Estate
  5. Re: A6 1.8T Oil consumption
    Feb 2007
    I now own an A6 1.9 TDI. Between 2002 and 2006 I drove an A6 1.8 TSE. Mileage was 67,000 in 2002 and 140,000 when I sold it. I couldn't fault anything other than the excessive oil consumption. I had to set the trip meter to remind me to top up the oil every 1000 miles. I was told that the oil seals could be the cause or possibly the turbo. I ended up just living with it, because it never got any worse and as one mechanic said to me, regularly buying a gallon of oil was cheaper that replacing oil seals or a turbo.
  6. Re: A6 1.8T Oil consumption
    Oct 2010
    salisbury uk
    I have a 2008 2.0 TFSI Petrol Avant. 26,000 miles. I have put over 7 litres of oil in over the last 10,000 miles. (i.e. 1350 miles per litre) I'm having this investigated.
  7. Re: A6 1.8T Oil consumption
    135 Post(s)
    2038 Post(s)
    Less than 1 litre per 1000, end of story…
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Peter D View Post
    My C5 A6 1.8T used a litre of oil in the first 6000 miles, then not a drop after that, until I swapped it 75000 miles later for my first C6. In complete contrast, the C6 2.0TDi PD used a litre of oil every 3500 miles!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  9. Re: A6 1.8T Oil consumption
    Jun 2007
    1.8 AEB. I use on average 150ml per 1000 miles. 62k on the clock and Castrol Edge 5/30. Long runs use less mostly due to no cold starts and under temp driving. Regards Peter
  10. Angry Re: A6 1.8T Oil consumption
    Oct 2010
    Kildare Ireland
    Use about a litre and a half for every 1000 miles, normally put in 5w30 but have been caught out at times and have to put in 10w40 which really flies out of it...
    car has 100k on engine
    1984 Golf GTI Mk2 Stolen but been restored
    1989 Golf GTI Mk2 Originally bought for parts but.....
    1999 Audi A6 1.8T Work Vehicle
    1983 Audi 100 2.3E Awaiting restoration
  1. Oil Consumption..!
    By Pimped-Passat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-01-2009, 05:18 PM
  2. Oil consumption
    By alecmac in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-08-2007, 06:14 PM
  3. Oil Consumption..! Take 2
    Last Post: 11-06-2007, 10:35 PM
  4. Fuel consumption
    By Maz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2007, 04:07 PM
  5. Oil Consumption
    By 1.8T_moans in forum New Member Introductions
    Last Post: 11-10-2006, 01:03 PM
