Thread: 2008 Audi A3 1.9tdi BXE Misfire
  1. 2008 Audi A3 1.9tdi BXE Misfire
    Aug 2012
    London
    Have a 2008 Audi A3 that has a rough misfire at idle shakes violently, when you bring rpm up it smooths out a bit but you can still feel the misfire. There is 4 fault for all the glow plugs but I don't think it will cause the misfire, but has a P0304 cylinder 4 Misfire. I checked the connections for cylinder 4 injector and the cam lobes and it looked all ok. I'm leaning towards the injector. Smooth idle running stabilization quantity are :
    Cyl 1 : 2.21
    Cyl 2 : -2.01
    Cyl 3 : -3.00
    Cyl 4 : 2.58
    I'm leaning towards the injector on 4 cylinder or are they all kaput. Any help appreciated..
  2. Re: 2008 Audi A3 1.9tdi BXE Misfire
    May 2012
    Everywhere
    308 Post(s)
    You've got some big end bearing shells to do too !
  3. Re: 2008 Audi A3 1.9tdi BXE Misfire
    2013 Post(s)
    I haven’t seen that for a while, what looks like all four injectors in trouble, if anything number 3 is the worst but in my experience ANY value over +/-1 mg is cause for concern.
  4. Re: 2008 Audi A3 1.9tdi BXE Misfire
    Aug 2012
    London
    Why do I get only cyl 4 Misfire code and not cyl 3 or any other?!
  5. Re: 2008 Audi A3 1.9tdi BXE Misfire
    2013 Post(s)
    Without being hands on I would suggest a new injector on number 4 first and then see what the values are. Fit a new head harness as a matter of course.
  1. Engine Misfire - Passat 2008 3.2 V6
    By ronnie136 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-09-2016, 07:56 PM
  2. 2008 A6 C6 3.0TDi Misfire
    By gazza57 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-04-2014, 01:08 PM
  3. 2008 A6 2.0 tdi bre , Misfire , hesitation , lack of power
    By kenmurray in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2013, 01:48 PM
  4. Audi A3 1.9tdi 2008 CHORUS Head-Unit Upgrade
    By sum-vwaudi in forum In Car Entertainment
    Last Post: 11-07-2011, 07:51 PM
  5. Slight misfire on 1.9tdi AWX audi a4
    By Buzzoff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-10-2010, 02:52 PM
