Thread: mmi oil level indicator
  1. mmi oil level indicator
    Sep 2008
    chester
    17 Post(s)
    The mmi oil level indicator is crap,(what are you thinking of audi)obviously this has been done to death on the forum!!!,my question has anybody got the measurement for the generic dipstick so I can get a more accurate level when doing an oil change,the engine is a CGLC 2.0 tdi,need the distance from the hilt to the min and max levels,my sons mk6 golf will fit down so I just need the distance so to dip it,also digging around on the web I see it takes 5 litres what your experience in the real world,regards.
  2. Re: mmi oil level indicator
    Mar 2007
    9 Post(s)
    Hi i do not think you can get a normal dipstick for this engine . i have the same engine in my a4 i bought a laser adjustable dipstick from ebay the setting for the 2.0 cglc is 46mm on the top scale on the bottom scale max oil level is 24mm and minimum oil level is 0. Engine oil capacity is 5 litres with the filter changed
  3. Re: mmi oil level indicator
    Sep 2008
    chester
    17 Post(s)
    Thanks for the reply,I've got a dipstick of a mk6 golf and need to know what the distance from the top clamp(hilt) down to the high mark and then to the lower mark in mm so I can transfer it to the other dipstick so as to get a reasonably accurate reading,I would appreciate it if you could measure it for me,regards.
  4. Re: mmi oil level indicator
    Mar 2007
    9 Post(s)
    hi on my laser dipstick minimum oil level from the stop ie dipstick fully in outer tube against the hilt the measurement is 520 mm . maximum oil level again fully in to the hilt 495 mm hope that helps
  5. Re: mmi oil level indicator
    Sep 2008
    chester
    17 Post(s)
    Exactly what I wanted,much appreciated.
  1. Question Oil level light on but oil level is fine (after recent oil change)
    By mvdg in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-11-2019, 09:10 PM
  2. Low Oil Level Warning Light on but level OK - Anything else to check
    By new2vwa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-10-2013, 07:03 PM
  3. Coolant level/temp indicator
    By markgrff17 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 14-05-2009, 02:43 AM
  4. Question Yellow warning indicator - Check Oil Level
    By nick.king in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-01-2009, 08:10 PM
  5. Washer water level indicator light
    By Fettler in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-01-2008, 09:07 PM
