Thread: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
Results 1 to 10 of 15
  1. A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    A3 CAYC 1.6Tdi starts then stops after a few seconds - it shows a brake fault on the dash but when scanned with VCDS there are no errors.
    Further investigation shows fault code for "Speed Encoder Errors 65535" on front right, front left, rear right and rear left if that has any relevance.
    Any help is much appreciated thanks
  2. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    Code:
    Wednesday,04,December,2019,17:10:56:42137
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    VIN: WAUZZZ8P1AA080971   License Plate:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 61
    VIN: WAUZZZ8P1AA080971   Mileage: 156870km-97474miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 M    HW: 03L 906 023 L
       Component: R4 1.6l TDI   H23 9979
       Revision: --H23---    Serial number: AUX7Z0I9FNQ0OX
       Coding: 00114016030501080000
       Shop #: WSC 06314 000 00000
       ASAM Dataset: EV_ECM16TDI02103L906023M 003017
       ROD: EV_ECM16TDI02103L997557R.rod
       VCID: 3038E0DC1AA91A17797-8064
    1 Fault Found:
    9874 - Boost Pressure Control Valve/Solenoid (Bank 1)
              P0045 00 [172] - Open Circuit
              MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 4
                        Mileage: 156868 km
                        Date: 2019.12.03
                        Time: 16:05:20
                        Engine speed: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 42 °C
                        Intake air temperature: 15 °C
                        Ambient air pressure: 1000 mbar
                        Voltage terminal 30: 12.424 V
                        Unlearning counter according OBD: 40
                        Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: 10.492 %
                        Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
                        High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.732 V
                        Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
                        Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.394 V
                        Charge air pressure: actual value-MAP_MMV: 200.00 hPa
                        Sensor for temp after charge air cooler: raw value-TBA_MES: 8 °C
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 BA    HW: 1K0 907 379 BA
       Component: ESP MK60EC1   H45 0109
       Revision: 00H45001
       Coding: 13422012092A00FAC81404EB901A00913800
       VCID: 72BC2AD4D4A56807CF3-8026
    No fault code found.
    Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
       Part No SW: 8P0 820 043 BK    HW: 8P0 820 043 BK
       Component: KlimavollautomatH09 0140
       Revision: 000425      Serial number: 8P0820043BK
       Shop #: WSC 00000 000 00000
       VCID: 76B416C4B4CD7427E3B-8022
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   105 0575
       Revision: 00105 AJ
       Coding: 0E000A2FB005F000207041E00000014C431A23AA004DC12AE4008F800041
       Shop #: WSC 00899 210 95606
       VCID: 323CEAD4142528070F3-8066
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 3 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H03 1301
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    1 Fault Found:
    01504 - Bulb for License-Plate Light (X)
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 99
                        Mileage: 156868 km
                        Time Indication: 0
                        Date: 2019.12.03
                        Time: 21:33:30
                 Freeze Frame:
                            Term 15 On
                        Voltage: 14.65 V
                            ON
                            ON
                            Term 50 On
                            OFF
                            OFF
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
       Component: Airbag AU1042 H06 0160
       Revision: --------    Serial number: 003FB003SKSM
       Coding: 303142413039303030384A55305238503053
       ASAM Dataset: EV_Airba10AURB4 001001
       ROD: EV_Airba10AURB4.rod
       VCID: 4FFA8320675765EF00D-801A
       Crash sensor for side airbag: driver side:
       Serial number: 34928RB400005147184C
       Crash sensor for side airbag: front passenger side:
       Serial number: 35028RB4000051C09247
       Crash sensor for side airbag: rear: driver side:
       Serial number: 35128RB400005147C1AF
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 35228RB40000514782EH
       Crash sensor for front airbag: driver side:
       Serial number: 35547RB40000518CC8D$
       Crash sensor for front airbag: front passenger side:
       Serial number: 35647RB40000518CC9C/
    Address 16: Steering wheel        Labels: 8P0-953-549.lbl
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Component: J0527           H37 0070
       Coding: 0002012
       VCID: 46D4A60484ADA4A7B3B-8012
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           H02 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 J    HW: 8P0 920 982 J
       Component: KOMBIINSTR. VDO H03 0990
       Revision: D0H03004    Serial number: 2249I004010854
       Coding: 0004428
       Shop #: WSC 54064 210 66681
       VCID: 40D8B01CA6898A97897-8014
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
       Component: J533  Gateway   H17 0231
       Revision:   H17       Serial number: 1321J09A23078E
       Coding: E9801F06100202040101
       VCID: 6B8237B0FF8FB9CF0C5-803E
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Revision: D0H03004    Serial number: AUX7Z0I9FNQ0OX
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
       Component: Tuer-SG         H04 0100
       Coding: 0131636
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 232    2901
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 2F3AE3A00B1705EF60D-807A
    Address 47: Sound System        Labels: 8Px-035-382.lbl
       Part No SW: 8P3 035 382 E    HW: 8P3 035 382 E
       Component: AB2 SUBWOOFERBOXH31 0160
       Revision: 00007       Serial number: 92157948699207
       VCID: 3536D1C8E94B3F3F2A1-8060
    Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
       Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
       Coding: 0131636
       VCID: 47CAAB0083A7BDAF48D-8012
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
       Component: R Concert2+     H03 0280
       Revision: 00H03000    Serial number: AUZ1Z3I5162009
       Coding: 0310011
       VCID: 42DCBA14A88598879F3-8016
    Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
       Part No SW: 1K0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H17 0231
       Revision: --------    Serial number: 1321J09A23078E
       Coding: 0303085A
       VCID: 688848BCE27992D7617-803C
       Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790115227
    End----------(Elapsed Time: 01:07, VBatt start/end: 12.2V/12.2V)-----------
  3. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    I disconnected the engine boost control valve so that fault isnt an issue. I also tried switching off stop/start but that didnt change anything. The ESP/ABS and handbrake warning light would flash as well when it wont start.
  4. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    133 Post(s)
    1982 Post(s)
    You have had a booster pack on there haven’t you?
  5. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    Yes sure have thanks Crasher. It broke down the day before, just stopped on the road. Its a EA189 car with the software update done. Would a failed EGR valve be responsible?
  6. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    133 Post(s)
    1982 Post(s)
    An immobiliser fault will not stop it when running, a low battery voltage will, giving it a 14.65v spike last night at 9.33pm could have upset the dash.
  7. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    Any ideas or suggestions for the best next step?
  8. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    133 Post(s)
    1982 Post(s)
    Charge the battery over night disconnected and try again.
  9. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    Oct 2017
    London
    12 Post(s)
    Apologies, I was reading my original post and I didnt mention that it stopped on the road altogether prior to this fault where it will now only run for a few seconds (poorly) before cutting out. There was no problem until it stopped and now it is doing everything I mentioned before. Could it still be the battery?
  10. Re: A3 CAYC 1.6Tdi Starts then stops after a few seconds - brake fault
    133 Post(s)
    1982 Post(s)
    That doesn't sound like the immobilser cutting the engine out, are you seeing no relevant fault codes still? You you have a multimeter so you can check the battery voltage? If it is the battery it should run on the booster pack and cut when that is disconnected.
  1. Question 1.6tdi CAYC Engine
    By djah in forum Golf MK6 - 2009 - 2013
    Last Post: 11-07-2019, 05:20 PM
  2. Please help vw passat 1,6tdi cayc
    By dorin in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 08-03-2018, 09:23 AM
  3. Question 2010 VW Polo 1.6 tdi, starts up but only runs for 2 seconds then stops
    By B1llyboy in forum Polo - Derby - Lupo - Fox
    Last Post: 13-12-2017, 07:37 PM
  4. a6 2.6 playing starts stops and no starts
    By jolleyalex26 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 12-10-2010, 08:43 PM
  5. Audi 80 auto 1.8 starts for 2 seconds then stops
    By timnewton30 in forum 80 - 90
    Last Post: 10-08-2008, 05:35 AM
