Thread: 2.0 TDI - How many thermostats are there??
  1. 2.0 TDI - How many thermostats are there??
    Jun 2016
    Hi All,
    I want to replace my thermostat which seems to be stuck open (temp gauge low, lower MPG, matrix not heating as fast) but I keep reading about more than one thermostat? How do you know which one is faulty? And is it a sealed unit or can you just replace the thermostat itself??
    THanks!
    J
  2. Re: 2.0 TDI - How many thermostats are there??
    Mar 2007
    9 Post(s)
    If it is manual there is one main stat autos have two there is a small one in a coolant pipe not sure where
  3. Re: 2.0 TDI - How many thermostats are there??
    Jun 2016
    Mine is an auto. Only one part seems to come up when I search for it so I got that one (thermostat plus housing) which fits between hoses. Gonna give it a go anyway
  4. Re: 2.0 TDI - How many thermostats are there??
    Jan 2009
    Birmingham
    36 Post(s)
    is this any help
    MENU
    < PREV PAGENEXT PAGE >
    Removing and installing 4/2-way valve with thermostat
    Special tools and workshop equipment required
    t Multi-point bit XZN 8 -T10445-
    Removing
    Note
    t The thermostat is located in the interior of the 4/2-way valve and cannot be renewed separately.
    t Remove engine cover panel -arrows-.
    t Open hose clips -arrows- and detach air hose.
    t Unplug electrical connector -2-.
    t Remove nut -1- and move bracket with electrical connector to one side.
    Drain coolant → Chapter.
    Detach coolant hoses from connections -A, B and D-.
    Remove bolt -2- with multi-point bit XZN 8 -T10445-.
    Remove bolts -1-.
    Pull valve out of cylinder block and detach connection -C- from coolant pipe to the left.
    Installing
    l Tightening torque → Chapter
    Installation is carried out in the reverse order; note the following:
    Note
    Fit new O-ring.
    Install throttle valve module -J338- → Rep. gr.23.
    Install alternator → Electrical system; Rep. gr.27.
    MENU
    Removing
    Note
    Remove bolts -1-.
    Installing
    Note
    Fit new O-ring.
  5. Re: 2.0 TDI - How many thermostats are there??
    Jun 2016
    [QUOTE=arman123;1112484]is this any help
    This looks like the part thank you!!! I'm gonna change it this week so will let everyone know how it goes
  6. Re: 2.0 TDI - How many thermostats are there??
    Mar 2012
    england
    Quote Originally Posted by sbt View Post
    I have been looking also so I have multitronic so there would be 2 then ? I also can’t find a video on it being done anywhere
  7. Re: 2.0 TDI - How many thermostats are there??
    Mar 2012
    england
    Quote Originally Posted by Joshua Dimbylow View Post
    Hi All,
    THanks!
    J
    This is my exact problem also didn’t notice the temp it was more the mpg going down the more I look I then notice it not warming to very well
  1. Cheap thermostats
    By mikeybutch in forum Chat - Anything with wheels
    Last Post: 17-12-2011, 05:55 PM
