Thread: 2.0 TDI - How many thermostats are there??
  1. 2.0 TDI - How many thermostats are there??
    Jun 2016
    Hi All,
    I want to replace my thermostat which seems to be stuck open (temp gauge low, lower MPG, matrix not heating as fast) but I keep reading about more than one thermostat? How do you know which one is faulty? And is it a sealed unit or can you just replace the thermostat itself??
    THanks!
    J
  2. Re: 2.0 TDI - How many thermostats are there??
    Mar 2007
    9 Post(s)
    If it is manual there is one main stat autos have two there is a small one in a coolant pipe not sure where
  3. Re: 2.0 TDI - How many thermostats are there??
    Mar 2012
    england
    Quote Originally Posted by sbt View Post
    I have been looking also so I have multitronic so there would be 2 then ? I also can’t find a video on it being done anywhere
  4. Re: 2.0 TDI - How many thermostats are there??
    Mar 2012
    england
    Quote Originally Posted by Joshua Dimbylow View Post
    Hi All,
    THanks!
    J
    This is my exact problem also didn’t notice the temp it was more the mpg going down the more I look I then notice it not warming to very well
  5. Re: 2.0 TDI - How many thermostats are there??
    Jun 2016
    Mine is an auto. Only one part seems to come up when I search for it so I got that one (thermostat plus housing) which fits between hoses. Gonna give it a go anyway
  6. Re: 2.0 TDI - How many thermostats are there??
    Jan 2009
    Birmingham
    36 Post(s)
    is this any help
    MENU
    < PREV PAGENEXT PAGE >
    Removing and installing 4/2-way valve with thermostat
    Special tools and workshop equipment required
    t Multi-point bit XZN 8 -T10445-
    Removing
    Note
    t The thermostat is located in the interior of the 4/2-way valve and cannot be renewed separately.
    t Remove engine cover panel -arrows-.
    t Open hose clips -arrows- and detach air hose.
    t Unplug electrical connector -2-.
    t Remove nut -1- and move bracket with electrical connector to one side.
    Drain coolant → Chapter.
    Detach coolant hoses from connections -A, B and D-.
    Remove bolt -2- with multi-point bit XZN 8 -T10445-.
    Remove bolts -1-.
    Pull valve out of cylinder block and detach connection -C- from coolant pipe to the left.
    Installing
    l Tightening torque → Chapter
    Installation is carried out in the reverse order; note the following:
    Note
    Fit new O-ring.
    Install throttle valve module -J338- → Rep. gr.23.
    Install alternator → Electrical system; Rep. gr.27.
    MENU
    Removing
    Note
    Remove bolts -1-.
    Installing
    Note
    Fit new O-ring.
  7. Re: 2.0 TDI - How many thermostats are there??
    Jun 2016
    [QUOTE=arman123;1112484]is this any help
    This looks like the part thank you!!! I'm gonna change it this week so will let everyone know how it goes
  1. Cheap thermostats
    By mikeybutch in forum Chat - Anything with wheels
    Last Post: 17-12-2011, 05:55 PM
