Thread: Passat Alltrack 2013 yellow Glow Plug flashing Light Snap On Code P253500
  1. Exclamation Passat Alltrack 2013 yellow Glow Plug flashing Light Snap On Code P253500
    Nov 2019
    Devon
    Hello,
    I have just purchased a Passat alltrack 2013 61K miles 2.0tdi Manual. Emissions update was done 27 months ago.
    All going well, it was serviced before I picked it up with new belts etc.
    however I have had a flashing yellow glow plug light from just after I picked it up, no issues with the drive, a message appeared on the display stating an issue with ‘start stop’ it has been intermittent but is on more time than not.
    I have had the fault read on a snap on suretrack reader, code P253500 Ignition switch run/start position circuit high.
    My mechanic hasn’t seen this particular code before, was wondering if anyone knew as to what this could potentially be.
    Im also thinking of getting the car remapped and the emissions update reversed, would this be advised?
    thanks in advance
  2. Re: Passat Alltrack 2013 yellow Glow Plug flashing Light Snap On Code P253500
    2014 Post(s)
    Ignition switch failure is common with this system used on many VAG products but I cannot see it causing the engine MIL to illuminate.
  1. Please Help Passat B6 EML and flashing glow plug light
    By MarkC89 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2017, 10:22 AM
  2. passat 58 flashing glow plug light
    By Danny Wood in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-02-2016, 12:09 PM
  3. Please Help passat b6 DPF FAULT LIGHT AND glow plug FLASHING.
    By usa in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2015, 02:39 AM
  4. B6 passat tdi glow plug light flashing
    By ctm73 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-06-2014, 09:36 PM
  5. Please Help Passat 2008 2.0CR TDI EML and flashing glow plug light
    By jasonmking in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-04-2013, 07:10 PM
