Thread: 009263 - Diesel Particulate Filter (Bank 1) Location
Results 1 to 8 of 8
  1. 009263 - Diesel Particulate Filter (Bank 1) Location
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Hi i cannot find the info i am looking for online, i have a dpf fault, came out of no where, car was fine for the last 2 years i only use it on the motorway x2 two hour trips every week, then once a fortnight x2 7 hour trips from Dudley west mids to Rochester, kent.
    so today the starter motor failed and dpf apparently.
    Sunday,24,November,2019,16:18:57:33186
    VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
    Ross-Tech: Home
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 4F9 910 402 A HW: 4F0 907 401 E
    Component and/or Version: 3.0TDI EDC17G000AG 0080
    Software Coding: 010D002C190F0128
    Work Shop Code: WSC 83529 676 460520
    VCID: 244D8445E75A5D6FE3-8070
    2 Faults Found:
    P242F - 000 - Restricted/Clogged
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 252682 km
    Time Indication: 0
    Date: 2019.11.24
    Time: 16:10:38
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    (no units): 1.5
    (no units): 21.5
    Mileage: 520 km
    Time: 0.00 s
    (no units): 8.0
    012372 - Starter Will Not Turn
    P3054 - 000 - Jammed or Electrical Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 252682 km
    Time Indication: 0
    Date: 2019.11.24
    Time: 16:13:49
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Voltage: 11.40 V
    Bin. Bits: 00000001
    Bin. Bits: 0
    Temperature: 16.2°C
    Bin. Bits: 00000001
    Readiness: 0 0 0 0 1
    it was a little slow starting yesterday but thought battery....
    so i have taken the exhaust off, and what i thought was the dpf, the dpf looks clear. though the fault wont clear even though the part is removed, i would have expected a different code...
    anyway this has got me thinking the dpf underneath the car is not the one throwing a fault. though etka discribe the cat at the side of the engine as a cat, and my part removed the dpf, where should i be looking?
    it is a 2010 A6 3.0 TDI Quattro Auto CDYA i think it is my dpf has 4F0131701EQ stamped on it.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: 009263 - Diesel Particulate Filter (Bank 1) Location
    131 Post(s)
    1973 Post(s)
    Battery looks a bit suspect according to the freeze frame data and a clogged DPF is nothing unusual, we have one of those in bits at the moment with a melted DPF.
  3. Re: 009263 - Diesel Particulate Filter (Bank 1) Location
    Dec 2007
    44 Post(s)
    So is there just the one dpf? And its under the car ?
  4. Re: 009263 - Diesel Particulate Filter (Bank 1) Location
    131 Post(s)
    1973 Post(s)
    Actually looking at yours it is different to the V6 we are doing which has the close coupled all in one system, yours is under the car with the catalyst separate and further back up, so yours is easier to remove and costs much less if it needs replacing.
  5. Re: 009263 - Diesel Particulate Filter (Bank 1) Location
    Dec 2007
    44 Post(s)
    I have the dpf under the car off, it looks spotless inside. 3 bolts on the flange have rotted out though due to heat.
  6. Re: 009263 - Diesel Particulate Filter (Bank 1) Location
    131 Post(s)
    1973 Post(s)
    Fit and calibrate a new sensor and try again.
  7. Re: 009263 - Diesel Particulate Filter (Bank 1) Location
    Dec 2007
    44 Post(s)
    So if i have it in regen mode via vcds would the glow plug light be flashing? So many codes for a 2009 A6 cdya
    But think i have it locked down to
    Security access 27971
    Then basic settings 226 go.
    Glowplug light then flashes but goes out if u touch anything.
  8. Re: 009263 - Diesel Particulate Filter (Bank 1) Location
    131 Post(s)
    1973 Post(s)
    I struggle to get VCDS to do regens on some cars so I usually use ODIS, in most cases I can remember the DPF light comes on but not a flashing glow plug.
  1. Please Help 009263 - diesel particulate fliter (bank1): restricted/clogged P242F
    By a4hitz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-05-2019, 03:09 PM
  2. Question 009263 - diesel particulate fliter (bank1): restricted/clogged P242F
    By a4hitz in forum VCDS - Help Requests
    Last Post: 06-05-2017, 09:10 AM
  3. Question Diesel particulate filter
    By smarb in forum Chat - Anything with wheels
    Last Post: 17-09-2014, 02:35 PM
  4. diesel particulate filter
    By barryn466 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-05-2011, 10:20 AM
  5. Diesel Particulate Filter (DPF)
    By El Guapo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-10-2008, 11:44 AM
