Thread: Running lean
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
  1. Running lean
    Dec 2017
    Lochgelly
    So I've posted before but never really got many replies but I'm really stuck and just don't know where to go from here.
    Car is holding revs, loss of power and fairly hesitant.
    I started off with a boost leak and since its been repaired my car has ran worse than ever and this code started happening
    16555(P0171) - Fuel Trim; Bank 1: System Too Lean
    Maf wasn't working as well as it should so has been replaced.
    Dv has been replaced for the newest revision.
    New spark plugs.
    New fuel filter.
    New n80 valve.
    New n75 after it was snapped.
    After testing a lot of these parts were due for change and not working correctly but it hasn't made a bit of difference to my problems really.
    Long term fuel trim are sitting at 25%. I'm going through petrol like it's going out of fashion, and I thought it was bad enough owning an s3!
    I'm feel like there is a bad connection under inlet manifold, so I'm going to strip and check tomorrow which I think might be the reason my revs are sticking but I'm at a dead end in terms of my lean running engine. Someone help a girl out?
    Sent from my SM-G965F using Tapatalk
  2. Re: P0171 system too lean
    2005 Post(s)
    Perhaps it is because we don’t know which car, year or engine type code you have and the post is in an odd place.
    Have you tried taking the oil cap off with the engine running?
  3. Re: P0171 system too lean
    Dec 2017
    Lochgelly
    Sorry I wasn't sure where to post, can I move it?
    Audi s3 2.0 tfsi. Yes I have doesn't run any different. I will add, I also have a pcv delete.
    It's running stage 2 Revo, full turbo back stainless, stage 3 intercooler, loba hpfp, pcv delete.
  4. Re: P0171 system too lean
    Dec 2017
    Lochgelly
    Also to add I made my boost leak again, and the car runs absolutely fine with having a the boost leak??
    I'm not sure what that says, it can't handle the extra air?
  5. Re: Running lean
    2005 Post(s)
    You could start by winding back the mods one at a time but is this an EA113 or EA888? Which PCV delete kit have you fitted? How does the crankcase now breath?
  6. Re: Running lean
    Dec 2017
    Lochgelly
    It's the ea113.
  7. Re: Running lean
    2005 Post(s)
    I would start by reversing some of the mods one at a time, to start with reinstate the original crankcase ventilation system with the updated valve 06F 129 101 R. Personally I would also do a system pressure test or smoke test to check for leaks.
  8. Re: Running lean
    Dec 2017
    Lochgelly
    Just looked and it's a Revo Pcv delete, I believe it gets redirected to the rear cam outlet. I don't have the original to put back it's been on the car for 2 years. I have smoke tested it and there is no more leaks. I was thinking that it must be a fuel related problem as I'm 99% sure I've ruled the air side of it out. My fuel rail pressure seems to be bang on with requested, and I have also swapped out both plugs on the hpfp.. so I was thinking it's got the be injectors or fuel pump, I'm not sure how to confirm either of them. My lpfp sits at 40% at idle and I've just replaced the fuel filter.
  9. Re: Running lean
    2005 Post(s)
    Injector failure is rare and for all four to fail equally... nah! Lean running is usually an air leak after the AMM.
  10. Re: Running lean
    Dec 2017
    Lochgelly
    How do you know all 4 have hypothetically failed equally, surely even if one or 2 have failed, then it would still be throwing more fuel into them all? If one had failed would my symptoms be any different? I will get the smoke tester back out today just to double check, but as I said I have already smoke tested it.
  1. Running lean tryed everything
    By troyritsema in forum 1.8T - Engine
    Last Post: 07-01-2018, 07:54 PM
  2. P0171 system running lean. Help please?
    By tobyg123123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-02-2017, 07:46 PM
  3. Audi S6 running lean
    By alinomie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-09-2010, 04:59 PM
  4. Please Help Golf 1.6 SE 8 Valve Running lean
    By obx102 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-12-2008, 03:15 PM
  5. Please Help MK3 ABF Running too Lean
    By Golf-Fiend in forum Golf MK3 - 1993 - 1999
    Last Post: 09-05-2008, 05:50 PM
