Thread: Sump Removal
  1. Sump Removal
    Oct 2009
    Malvern
    Can I remove the sump from my 3.0L TDI with the engine in the car? I know I have to remove the splash guard but can the sump be removed easily? I reason I need to remove it is there's a rust bubble in the corner and I'm worried if this rusts anymore the oil will all leak out! See photo attached. I'm thinking whether a local workshop could grind and weld this up or do I need to source a replacement sump cover?Oil Service 37,098 miles with Rust Spot.jpg
    Audi A4 3.0TDI Q SE Lava Grey + B&O, Audi Drive Select, Sports Seats, Sun Roof, DVD Sat Nav Plus, Blue Tooth Phone Prep, Audi Hill Assist, Rear Parking Aid, Electric Seats, Light Pack, Audi Audio Interface, MMI etc... and 4 Halfords Bulbs lol....
  2. Re: Sump Removal
    Oct 2009
    Malvern
    Can I have a reply on this one as I need to do a service but I need to sort out this problem? Thanks.
  3. Re: Sump Removal
    Oct 2009
    Malvern
    Can I have your advice please?
  4. Re: Sump Removal
    Jan 2020
    Shefford
    12 Post(s)
    I can’t answer you question because I don’t know the answer but you may want to ask at your local dealer. In my experience they are normally happy to offer advice.
  5. Re: Sump Removal
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Is there any warranty left on the car? If so get it looked under that.
    If not it doesn't look to be very deep. Wire brush on a drill plus a dab of Hammerite would probably stabilise it.
  6. Re: Sump Removal
    Jan 2009
    Birmingham
    36 Post(s)
    Removing and installing sump (bottom section)
    Special tools and workshop equipment required
    t Electric drill with plastic brush
    t Safety goggles
    Removing
    Draining engine oil, filling up with engine oil and checking oil level → Booklet811, → Booklet812 or → Booklet818.
    Remove nuts -arrows- and lower anti-roll bar.
    Unplug electrical connector at oil level and oil temperature sender -G266--item 1-.
    Remove bolts and pry off sump (bottom section) -arrow- carefully.
    Installing
    Caution
    Protect lubrication system and bearings against contamination.
    Cover exposed parts of the engine.
    WARNING
    Protect eyes against injuries.
    Wear safety goggles.
    Remove remaining sealant on bottom and top sections of sump with a rotating plastic brush or similar.
    Clean sealing surfaces; they must be free of oil and grease.
    Note
    Note the use-by date of the sealant.
    Cut off nozzle of tube at front marking (nozzle Ø approx. 1.5 mm).
    Caution
    Make sure lubrication system is not clogged by excess sealant.
    The bead of sealant must not be thicker than specified.
    Apply bead of sealant -arrow- onto clean sealing surface of sump (bottom section) as shown in illustration.
    l Width of sealant bead: 2 mm.
    Note
    The sump (bottom section) must be installed within 5 minutes after applying the sealant.
    Fit sump (bottom section) and tighten bolts → Fig..
    Install anti-roll bar → Rep. gr.40.
    Install front noise insulation → Rep. gr.66.
    Fill up with engine oil and check oil level → Booklet811, → Booklet812 or → Booklet818.
    Power unit > 6-cylinder TDI engine (2.7 ltr.; 3.0 ltr. 4-valve common rail), mechanics > Engine lubrication > Oil pump and sump (bottom section) > Removing and installing sump (
  1. help sump removal....
    By evorocket in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2011, 07:21 PM
  2. Oil Sump/Pan removal
    By sabikeuk in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-06-2010, 01:57 AM
  3. 6n2 gti sump removal
    By dantheram in forum Polo - Derby - Lupo - Fox
    Last Post: 16-03-2010, 02:46 PM
  4. Please Help T4 Sump removal
    By wardy1 in forum The Commercial Range
    Last Post: 27-07-2009, 09:22 PM
  5. Question Oil sump removal
    By Redkev in forum New Member Introductions
    Last Post: 17-06-2009, 09:10 PM
