Thread: Viscous Fan Bracket.
Results 1 to 10 of 20
  1. Viscous Fan Bracket.
    Lincolnshire
    Recently I noticed that there was a squeak coming from the viscous fan bracket (059 121 313 F / 059121313F). Having removed the bracket, it was obvious that the bearing that is pressed into it is now no good. I did some research and I can't find anything at all that offers any help other than buying another bracket at great cost.
    I thought I would offer my experience in the hope it will save somebody some hassle and maybe some money.
    So this is the bracket, and as you can see I've got a puller on the pulley.
    Now with the pulley removed below.
    You can see from the image below, you can see the original bearing is on the left. The bearing is actually a FAG WS2263 which is in fact a water pump bearing, these are no longer available so what I did was to buy a new bearing from a different manufacturer however the centre shaft is I bit too long and needs reducing in length. The one in the centre it the new unmodified bearing, and the one on the right is the modified bearing and has its shaft slightly reduced in length to match the original.
    Below is the length of the original bearing.
    I used a 32mm long socket to aid in pressing out the bearing, see next picture
    The bearing needs to be able to fit inside the socket
    Below, I'm now pressing out the bearing.
    So now you can see the bearing is being pressed out of the bracket and into the socket.
    Bearing now out
    So now the bearing is pressed into the bracket, you now have to press the pulley onto the bearing shaft. You can't just press it on though as that would damage the new bearing, so what you have to do is support the shaft. That way all the force is only on the shaft and not the balls inside.
    What I've done here is use the old bearing shaft up against the new bearing shaft. I turned this over to press the pulley on.
    You can see the pulley being pressed on, and you might be able to just make out the old bearing underneath supporting the new one.
    I hope this may be of use to somebody one day.
    0 2 0
  2. Re: Viscous Fan Bracket.
    Mar 2016
    Minervois, France
    54 Post(s)
    Neat But couldn't you just have left the shaft a bit longer? Or would that interfere with something?
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
  3. Re: Viscous Fan Bracket.
    Lincolnshire
    I had to shorten the shaft otherwise the auxiliary belt would hang off the pulley by about 3mm, I know, I tried it without shortening and wasted a bearing. Definitely needs shortening.
  4. Re: Viscous Fan Bracket.
    Mar 2016
    Minervois, France
    54 Post(s)
    I was thinking you could have left the shaft protruding 3mm, or whatever the measurement is, beyond the pulley face.
  5. Re: Viscous Fan Bracket.
    Jul 2020
    FINLAND
    Thank You for your exact info. It was most usefull to me. Best regards from Finland.
  6. Re: Viscous Fan Bracket.
    2018 Post(s)
    I know its old but 059 121 313 F isn't the part number, it is another example of VAG's highly annoying casting number system which look like part numbers. The actual spare part number is 059 122 303 which retails at £303.90 inc VAT, daft for a worn bearing.
  7. Re: Viscous Fan Bracket.
    Jun 2021
    UK, Surrey
    Just looking into this for my fathers car, this and the bloody alternator tensioner pivot pins/bushes, utterly stupid design that I had to take the whole bracket off to release the bolt for the pin!! (typical VAG!).
    Anyway, that aside, thanks for your excellent information and photos Seanious
    FrenchAudi
    There is no hole for the shaft to poke through the pulley.[edit] Correction, there is a hole, but it's smaller than the shaft.
  8. Re: Viscous Fan Bracket.
    Lincolnshire
    Quote Originally Posted by Assimlator1 View Post
    FrenchAudi
    No probs mate anytime
    Sean
  9. Re: Viscous Fan Bracket.
    Jun 2021
    UK, Surrey
    Now I've just got to see if I can find something to pull off the flange (none of our workshop pullers fit), or a big enough collar to push out the bearing with the flange, none of the ones I found in the box of bits were big enough!
  10. Re: Viscous Fan Bracket.
    Lincolnshire
    Are you anywhere near Lincoln?
    I used a press to get it out. The silver/blue collar is pretty hard to remove. If you are near me, I'll push it out for you.
    Sean
  1. Viscous Fan
    By darthweasel in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-10-2011, 01:53 PM
  2. Viscous fan.
    By routers77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2009, 07:48 AM
  3. viscous fan hub
    By strangey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2008, 08:30 PM
  4. Viscous fan
    By LtsMan in forum The Commercial Range
    Last Post: 29-01-2008, 06:24 PM
  5. viscous fan
    By a4fooltdi in forum Audi A4 - Archive Topics
    Last Post: 30-05-2007, 10:29 PM
