Thread: Audi A3 2.0TDI P2015 code Engine not starting
  1. Audi A3 2.0TDI P2015 code Engine not starting
    Oct 2019
    Milton Keynes
    Hi There
    I have an Audi A3 2.0tdi 2009. Last week the car had problems starting but eventually did after 20 minutes or so. Today when I have gone to start it, the same thing happened. However this time it hasn't started at all. Dash lights come on as normal but when starting it, it does not crank over and the dash lights stay on. After plugging it in it comes up with code P2015. We deleted the code but just reappears straight away again. The actuator arm is moveable which is why I dont think it's the switch??? Has anyone had any experience with this? Any advice would be greatly received.
    Many thanks
  2. Re: Audi A3 2.0TDI P2015 code Engine not starting
    2019 Post(s)
    18447 (P2015) - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
    That code is irrelevant to the not turning over, firstly, get the battery on charge.
  3. Re: Audi A3 2.0TDI P2015 code Engine not starting
    Oct 2019
    Milton Keynes
    Thank you for reply... Sorry forgot to say battery already been charged. It's reading 12.6v. Also just tried starting it with a jump pack. Lights, heating, air con still comes on
  4. Re: Audi A3 2.0TDI P2015 code Engine not starting
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Sounds like your starter motor might be goosed.
    You need to jump a wire between the battery + to the starter solenoid, by-passing the ignition controls, ( make sure gearbox is in neutral first ) if the engine doesn't turn over the starter motor will need replacing.
  5. Re: Audi A3 2.0TDI P2015 code Engine not starting
    2019 Post(s)
    The starter is controlled by the central convenience unit which is commanded by CAN BUS signal from, the steering column electrics unit which gets signals from the ignition switch, these switches often fail so I would get it code read and measuring block tested first.
  1. Please Help Audi A4 1.8TFSI P2015 engine management light.
    By RichardSharp in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2021, 09:29 PM
  2. Question Clutch and Flywheel kit for Audi A6 C7 2.0tdi 177bhp with CGL engine code
    By finn1965 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-12-2016, 08:02 PM
  3. Question 2009 Audi A3 2.0TDI CR (170PS) - P2015 and now P0299
    By achundee in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 04-08-2015, 02:06 PM
  4. A4 tdi p2015 fault code
    By b13jus in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-03-2014, 07:05 PM
