Thread: Golf VR6 2.8 engine strip and rebuild
  1. Golf VR6 2.8 engine strip and rebuild
    Jan 2009
    Nuneaton England
    6 Post(s)
    Hi All
    I have been on this forum for a good few years now and realy enjoy the help and advise given and received
    I have recently purchased a Golf Mk3 2.8 VR6 with just short of 150,000 miles on the clock, it feels like over the years a few of the ponies have left the stable
    So I have removed and stripped the engine.
    Found a bit of ware on the piston bores and valve seats. So.Cylinder stripped, cleaned, new guides, seats and seals looking nice.
    Cylinder block in for 1mm oversize rebore Mahle pistons already purchased.
    Crankshaft in for a check and polish (when returned I will order a set of shells)
    New
    parts siting ready to go:
    Complete gasket set and seals
    Headbolts
    Complete chain kit and tensioners
    Water pump
    Oil pump
    Auxiliary belt
    As the build progresses I will add photos
    Now my question is:
    When it comes to the engine rebuild I will need a manual/torque settings:
    Headbolts
    Big end bolts
    Crankshaft bearing carrier bolts
    Flywheel bolts
    To name a few
    Can anyone help please with the details/manual
    Thanks in advance
  2. Re: Golf VR6 2.8 engine strip and rebuild
    131 Post(s)
    1974 Post(s)
  3. Re: Golf VR6 2.8 engine strip and rebuild
    Jan 2009
    Nuneaton England
    6 Post(s)
    Thanks for the links Crasher
  1. Engine strip inspect and possible rebuild.
    By patrick_c99 in forum Golf MK2 - 1984 - 1992
    Last Post: 30-04-2015, 09:41 PM
  2. Please Help Help needed on Door Lock strip down and rebuild
    By rosso rocket in forum Golf MK4 - 1999 - 2004
    Last Post: 29-12-2012, 05:30 PM
  3. Clutch rattle = Gearbox strip and Rebuild
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-05-2011, 11:08 PM
  4. How to strip and rebuild a rear caliper
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-09-2009, 05:11 PM
  5. Golf 1.4 engine rebuild..HELP!
    By tona955 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-02-2009, 01:44 PM
