Thread: Help with Codes 17580/P1172, 17579/P1171
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
  1. Help with Codes 17580/P1172, 17579/P1171
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Got an issue with my Golf Mk5 1.6 FSI.
    FULL AUTO SCAN:
    Code:
    Chassis Type: 1K (1K0)Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W096975   Mileage: 316260km-196514miles
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 BA    HW: Hardware No
       Component: MED9.5.10       G00 5697
       Revision: 00000000    Serial number: VWZ7Z0D9331576
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 63C1C201A2D6B057DA-8036
    1 Fault Found:
    17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
                P1172 - 002 -
    Readiness: 0100 0000
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A7F5F6575DC919FA9-806E
    1 Fault Found:
    01314 - Engine Control Module
                013 - Check DTC Memory
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   080 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C7DB1551E4C57F3D-8032
    No fault code found.
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000514812
       Coding: E48D0F0600041800001400001400000000
       VCID: 3779465146CE8CF756-8062
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08P0VC
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A5F6F25857C211FD9-807E
       Subsystem 1 - Serial number: 6332MSME5D7E1002
       Subsystem 2 - Serial number: 6342MSME57340A02
       Subsystem 3 - Serial number: 6351HSME43485801
       Subsystem 4 - Serial number: 6361HSME5D0F5901
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 306B7D4DA3A05BCF17-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3554
       Coding: 0000401
       Shop #: WSC 00218 210 03908
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100104128EF35
       Coding: 3D0F0340070003
       VCID: 27599611966E1C77C6-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3554
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2E576335B9944D3F05-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81E802087F2D8505485BC61000
       Shop #: WSC 00218 210 08203
       VCID: 7BF19A613A666897F2-802E
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316D7849A8AA52C718-8064
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D556439B49236273C-8078
    End-------------------------(Elapsed Time: 01:35)--------------------------
    VCDS is showing fault with throttle body:
    17580 / P1172 - Angle sensor 2 for throttle actuator G188 signal too low.
    or (on other scans show)
    17579 / P1171 - Angle sensor 2 for throttle actuator G188 implausible signal.
    also fault showing with ABS brakes:
    01314 - Engine Control Module - 013 - check DTC memory
    Car will drive for a bit when DTCs are cleared and throttle body adapted but then will go into limp home
    mode (can't go above 3000rpm).
    Have tried a second hand throttle body but still getting the same issue (but less often / sporadically)
    (reading MVB 062 in VCDS shows steady values / signals for G187 and G188).
    However the original throttle body I had on there was definitely on the fritz (or could be bad wiring,
    connectors or ECU damp?) as when reading measuring block values / MVB 062 you could see sensor
    2 G188 fluctuating wildly and not holding a steady value when at idle position
    Don't want to fork out for an OEM throttle body at £500!
    But also don't want to buy a cheap knock off.
    Any advice on this issue would be greatly appreciated.
  2. Re: Help with Codes 17580/P1172, 17579/P1171
    132 Post(s)
    1979 Post(s)
    Did you make sure the used throttle body was the correct part number, perfectly clean inside and then adapt it to the ECU in Basic Settings 060?
  3. Re: Help with Codes 17580/P1172, 17579/P1171
    Jul 2018
    8 Post(s)
    Hi Crasher I tried a new throttle body (not an oem part / aftermarket - metzger) and still had the same issues / showing same codes. What would you recommend doing next?
  4. Re: Help with Codes 17580/P1172, 17579/P1171
    132 Post(s)
    1979 Post(s)
    Can you rind me the part number of the Metzger throttle body? Did you do Basic Settings 060?
  5. Re: Help with Codes 17580/P1172, 17579/P1171
    Jul 2018
    8 Post(s)
    Yes I reset the throttle body using basic settings group 060 on vcds..... followed the instructions as per the ross tech video
    Part number for Metzger Throttle Body is ARTICLE №: 0892429
  6. Re: Help with Codes 17580/P1172, 17579/P1171
    132 Post(s)
    1979 Post(s)
    The OE number is 03C 133 062 A and this cross references on Tec Doc as a Metzger 0892429 so that is correct, leaves me a bit stuck...
  7. Re: Help with Codes 17580/P1172, 17579/P1171
    Jul 2018
    8 Post(s)
    Going to try and take a look at the wiring a connectors between the throttle body and Ecu.
    There is a TSB 2018652 which splices in 6 new wires to the throttle body (just the last 12 inches).
    Fingers crossed with new connector, new terminal pins and wiring it will resolve the issue.
    If if not I’m stumped too or it’s an ECU issue?
  8. Re: Help with Codes 17580/P1172, 17579/P1171
    132 Post(s)
    1979 Post(s)
    I would be replacing the pins at both ends with Gold plated ones as I stock them and have the crimps but you may have to use VAG repair wires which I don’t like.
  9. Re: Help with Codes 17580/P1172, 17579/P1171
    Jul 2018
    8 Post(s)
    Thanks for the advice Crasher.
    How would I obtain these pins and crimps from you?
    What are the VAG repair wires? Is there a part number?
  10. Re: Help with Codes 17580/P1172, 17579/P1171
    132 Post(s)
    1979 Post(s)
    I think it is an AMP mini timer without being able to check at work, I get them from Buy Flat plug contact Junior Power Timer (JPT) 2.8 online
    And these to crimp them on
    Buy Crimping tool for uninsulated flat connectors (0714104121) online
    The VAG repair wires are available from VW dealers or TPS if you have an account
    These aren’t the correct numbers but give you the idea
  1. Question DTC codes
    By stuart73 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-10-2019, 12:36 PM
  2. VAG Workshop Codes [WSC] - anyone recognise these UK codes please? ...
    By JulianHicks in forum VCDS - General Questions
    Last Post: 09-07-2015, 09:53 PM
  3. tax codes
    By sbt in forum Chat - Completely Off Topic
    Last Post: 06-02-2011, 10:41 PM
  4. I know, I know! get codes!!
    By craicdealer in forum Polo - Derby - Lupo - Fox
    Last Post: 18-01-2011, 04:48 PM
  5. OBD Codes
    By ilfdlab in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2008, 11:29 AM
