Thread: Car not reaching running temp? :(
  1. Car not reaching running temp? :(
    Nov 2019
    united kingdom
    Morning All,
    2004 Audi A4 B6 1.9tdi 130 Sport
    Recently replaced the coolant flange at the rear of the engine and hose to the heater and filled up with new coolant if that could have anything to do with it. I've tried bleeding the system twice to see if that helps.
    Basically the car used to get to 90c on the gauge and stay there. Now it only starts to climb in temp if I drive the car, idling barely moves it.
    This morning I drove to work then drove in circles round the car park to bring the temp up close to 90c as I could. When parked it drops more. The Gauge shows abit below 90c and VCDS ranges between 75c - 80c max
    Heres some images of the gauge and my reading from VCDS that I had running while driving.
    I'm not sure how to diagnose it exactly and what to replace first
    Click for Link to photos
    Thank you
  2. Re: Car not reaching running temp? :(
    131 Post(s)
    1979 Post(s)
    Straight away something is wrong there, the gauge never tells the truth. I would suggest firstly you change the thermostat.
  3. Re: Car not reaching running temp? :(
    Nov 2019
    united kingdom
    Ordered thermostat off ECP, could go dealership but used Circoli Brand for my waterpump and no issues so far touch wood.
    Circoli Thermostat | Euro Car Parts
    Is there any diagnostics I can do really or just go straight in and replace it?
  4. Re: Car not reaching running temp? :(
    131 Post(s)
    1979 Post(s)
    The diagnostics you have done so far suggest the thermostat and what you are doing is what a mechanic would do.
  1. flashing temp light / correct running temp
    By passat newbie in forum Early Passat Forum - Pre 97
    Last Post: 05-12-2010, 02:21 PM
  2. Question What's the running temp?
    By Shaunbing in forum Golf MK3 - 1993 - 1999
    Last Post: 20-06-2009, 07:50 PM
  3. 1.8T: Low running temp
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2008, 07:30 PM
  4. audi running temp
    By mrmagoo in forum 80 - 90
    Last Post: 03-06-2008, 08:41 PM
  5. Please Help running problem at certain temp
    By mattbutt in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 17-05-2008, 11:09 PM
