Thread: mysterious bolt
Results 1 to 10 of 10
  1. Question mysterious bolt
    Aug 2007
    Just changed my cam belt and right at the end of the job i came across this bolt!!
    I have racked my brains trying to think if i took it out or not.
    I've looked at the haynes manual and traced back my steps....
    any ideas as it looks pretty important
    i took the front bumper off and dropped the radiator and frontpanel etc down to get to the bottom 4 bolts in the pulley.
    it's an 8mm thread with a 13mm hex head 25mm long thread from under the head
    the washer appears to have a witness mark like you find on an adjustable bracket and it has belt soot over the head and washer.
    http://i7.photobucket.com/albums/y25...t/100_1871.jpg
    car is in my sig
    cheers
    My Car: 1997(R) A4(B5) 1.9(AHU) TDI SE 66kw(90HP) Auto(DMV)
    Quote by RAM Circa 2003 " Why would I want a VAG-COM and WT* is it anyway??"
  2. Re: mysterious bolt
    May 2007
    knee deep in clunge
    14 Post(s)
    it looks like the ribbed v belt lower tensioner retaining bolt or the cam pulley has three bolts the same as this and if you have followed the correct procedure you would have loosened these but not removed to allow for belt movement when removing and installing,theres one other possibility and thats the lower front engine mount support which has two simmilar bolts that secure the casing to the lock carrier,but you shouldnt need to remove this.
  3. Re: mysterious bolt
    Aug 2007
  4. Re: mysterious bolt
    Aug 2007
    Cam pulley only had one large bolt in the center
  5. Re: mysterious bolt
    May 2007
    knee deep in clunge
    14 Post(s)
    Attachment 1380sorry thought it was pd engine so it could be one of the front lock carrier bolts
  6. Re: mysterious bolt
    Aug 2007
    no probs, could well have been left there by a previous mechanic and now i've had the under tray half off it has been let loose to bug me for the next few days.
  7. Re: mysterious bolt
    May 2007
    knee deep in clunge
    14 Post(s)
    have another look at the previous answer as there is a picture of the lock carrier from the outer but there are two bolts on the inner for the lower engine support and have you got a/c compressor as the belt adjuster is either a allen key or 13mm bolt
  8. Re: mysterious bolt
    Aug 2007
    yea Air con was 6mm cap heads for adjustment,
    the lock carriers were all torx 45 head but there were 4 on the drivers side and 2 on the passenger side, could they use a hex head as one of these bolts?, seems a bit short against the torx they were all 50mm+ long. dammed if i can remember using a 13mm socket to get one off.
  9. Re: mysterious bolt
    May 2007
    knee deep in clunge
    14 Post(s)
    Attachment 1382 there is a bolt above the alternator number 11 as the lock carrier has the original torx head bolts
  10. Re: mysterious bolt
    Aug 2007
    ok ill sleep easier knowing that its not critical to the cam belt operation, will have a look when its not bagging down with rain and hale. pretty sure that number 11 is in place and doesnt have such a big washer behind it.
    thanks for your help.
  1. Upper hub bolt - siezed?
    By vwmark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2008, 05:59 AM
  2. Mysterious Beeps....
    By JasonY in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2007, 06:24 PM
  3. A4 Hub/Bearing Bolt-On
    By ChrisFurlong in forum Audi A4 - Archive Topics
    Last Post: 30-08-2007, 06:55 PM
  4. mysterious occausional missfire/shuddering
    By quattro kev in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-06-2007, 08:50 PM
  5. bolt pattern
    By stuvette in forum Chat - Completely Off Topic
    Last Post: 05-06-2006, 09:30 AM
