Thread: Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
    Jun 2012
    Surrey
    6 Post(s)
    Long update and continued issue!#
    The replacement sensor cleared the fault code but we could not regen the DPF, various scans and a DPF clean plus driving up and down it all sorted, out of limp, DPF cleaned. Ran fine for 1000 miles or so.
    Then the glow plug light popped on, then the MIL one then the DPF one!! not in limp but obviously not happy again.
    Scanning seemed to indicate square one...temp sensor 1 bank 1 again . got another on warranty, fitted, fault code clear and drove it to regen the DPF...all worked lights all out!! woohoo.
    So about 300 miles later glow plug and MIL light come on again............sensor 1 bank 1 again!
    It is a pattern part.....is there a known issue with these? could the car ECU be rejecting the sensor soon after fitting and accepting it?...think you will know what I mean.
  2. Re: Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    I have seen a previous post re this issue with repeated failures of this sensor.
    In that case it was a slight leak of the head gasket.
    The superheated steam generated in combustion was destroying the sensor.
    Is your engine using any coolant ?
  3. Re: Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
    Jun 2012
    Surrey
    6 Post(s)
    No use of coolant, never ever needed topping up in use. Clean pink coolant, and no signs of issues with head gasket thanks for input.
    I wonder if it could just be a crap sensor supply??
  4. Re: Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    As far as I know these are 2 wire sensors ( Just 2 connections in the plug ) so are either resistive, where the resistance changes with temperature, or they give out a small voltage which varies with temperature.
    So they wouldn't rely on a supply voltage from the ECU.
    I would try a genuine VW replacement which I think comes with a 2 year warranty.
  5. Re: Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
    134 Post(s)
    2019 Post(s)
    What is the make and part number of the sensor?
  6. Re: Exhaust Gas Temperature Sensor, Bank 1 sensor 1.
    134 Post(s)
    2019 Post(s)
    The OE number is 03L 906 088 BS, what did you fit?
  1. P246e bank 1 exhaust gas temperature sensor 4
    By Dorra69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-04-2023, 12:01 PM
  2. P0546 Exhaust Gas Temperature Sensor Circuit High (Bank 1)
    By nick.king in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-07-2019, 07:18 AM
  3. Question Exhaust Gas Temperature Sensor Bank 1 Sensor 1 fault -> more noise?
    By tomas_v in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-02-2018, 12:32 AM
  4. 02 Sensor - Bank 2 - Sensor 1, location.
    By Biggaz1979 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-04-2016, 03:17 PM
  5. please help! where is 02 sensor bank 1 sensor 2 on A4 1.6 2001?
    By emma and neil in forum New Member Introductions
    Last Post: 05-06-2011, 10:57 PM
