Thread: VW Passat Sluggish
  1. VW Passat Sluggish
    Sep 2019
    Glasgow
    I have a 2014 VW Passat 2.0TDI 140.. Within the last year it’s became sluggish like a car that has same engine but much less horsepower. When sluggish the engine is rather noisy aswell like a growling sound with little power from low rpms. Yet I get intermittent spells where the car drives as it should where I don’t need to accelerate beyond 2000rpm plus there’s no growling noise too the engine sounds as it should..
    The car when sluggish isn’t dangerous but as I drive all day it annoys me big time and burns more fuel I reckon.
    I got a new Clutch/DMF fitted earlier this year and it’s made no difference. It’s been checked for any exhaust and boost leaks all was ok here. I have let the Garage drive it and they said it’s fine. Anybody else in the car also said it sounds fine but clearly it’s not. Was never this way before.. No lights nothing showing up either..
    Has anybody had this or similar problem. Getting to the stage it’s so annoying I would be better getting shot of it..
  2. Re: VW Passat Sluggish
    Jul 2020
    Manchester, United Kingdom
    How about the spark plugs?
  3. Re: VW Passat Sluggish
    Feb 2017
    Yorkshire
    The post is almost a year old. I'm pretty sure that OP is done fixing the issue.
  4. Re: VW Passat Sluggish
    1837 Post(s)
    Quote Originally Posted by airgovea View Post
    Quote Originally Posted by 3stwart View Post
    and it’s a Diesel!
  5. Re: VW Passat Sluggish
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
  6. Re: VW Passat Sluggish
    Sep 2019
    Glasgow
    Although the thread is old now I may aswell tell you how I got on anyway. Pre Pandemic my active DPF regens would never complete aswell with warning light coming on everytime and would have to drive 15-25 miles for it to go off. The car was diagnosed to have faulty injectors as my “oil pressure warning” was now another issue with fuel diluting the oil with levels rising. Got nearly new injectors and an oil change and still no difference noisy unrefined sluggish car with the unsuccessful DPF regens. According to a scan it had not done a successful regen for over a year. Oil levels after so many thousand again brought warning on.. Second opinion was told it is the DPF needs replaced so get rid of the car. P2196 running rich code was always there. After another service decided to buy a Bosch Genuine O2 sensor. Replaced that myself and suddenly the car ran properly with a quieter engine, faster and much better fuel consumption. DPF regens returned to work as normal.
    Originally I had mentioned to the garage that could it be O2 sensor they said No. Turns out this was my problem all along faulty O2 sensor causing it to overfuel. So injectors were never the issue a £160 sensor cured it all.
    Changed car for a Passat B8 2.0tdi 150 DSG.. Not so impressed with this car though.
  7. Re: VW Passat Sluggish
    Aberdeen
    63 Post(s)
    At least you got it fixed!
  1. passat 2.0tdi very sluggish
    By Mikey1756 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-09-2016, 10:27 PM
  2. 1.9 tdi really sluggish
    By zmotor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-01-2015, 10:08 AM
  3. Sluggish A3
    By Jimbojofre in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-08-2011, 12:07 PM
  4. Please Help Passat 2001 2.0se.... sluggish engine cuts out at med/high revs
    By Guytheflyguy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-06-2010, 07:07 AM
  5. Please Help MK4 TDI Sluggish after New Cam
    By rossmurawski in forum Golf MK4 - 1999 - 2004
    Last Post: 26-08-2008, 09:13 PM
