Thread: a4 build up of water
Results 1 to 8 of 8
  1. a4 build up of water
    Aug 2006
    ive noticed a lot water in the drivers side footwells .ive tried my best to locate were water is coming from , sunroof drainage holes, under the bonnet, door seals though im not too sure what to look for there.The windscreen although secure doesnt look quite right.Is it possible to take drivers seat out without too much aggro enabling me to dry the carpet and sound proofing and check more thoroughly to see where the water is coming from?
    Maidstone
    hi
    read something about this eleswhere in the forum
    check under the bonnet where the battery and pollen filter are located for blocked drainage holes that cause build up of water.
    hope this helps
    s9
    Audi S5 3.0TFSI 354 Quattro Sportback 8sp Tiptronic 2018
  3. Believe it or not
    I had a similar issue, with major amounts of water appearing in the rear passenger footwell and some in the front.
    The funny thing was it was always damp, but the water level seemed to go up and down [and fill up really quickly].
    I also had a dodgy heater blower at the time and after hunting round for new brushes or a blower assembly I finally found an assembly at a scrappies.
    I had my suspisions that it was a combination of the the aircon/faulty blower, and this proved to be correct as about a week after fitting the new blower the footwells were dry and the problem has not reappeared in the six months since!
  4. Water in footwell
    Oct 2006
    Without a doubt the water in the footwell is caused by a blockage of a drain hole which is under the battery. It is normally caused by leaves and other rubbish falling between the windscreen and the bonnet. The water level builds up on the left hand side and floods through the bonnet release cable gland through the bulkhead into the footwell. Hope this helps.
    Jul 2006
    Quote Originally Posted by abaker View Post
    This could be caused by the heater matrix being faulty.
    I had this problem with a Nissan Bluebird 2.0 Diesel I had years ago. Most of the dashboard had to come out to get to it.
    1996 Audi A4 1.9 TDI SE 110bhp
    Had this problem on my 2003 Audi A4. It turned out to be a poorly bonded wind screen. Replaced by my local Audi garage under warrenty
  7. water in passenger footwells front and rear
    Dec 2006
    i also have water in the passenger footwells, the front is not bad but the back is a lot, also my heater blower hasnt been working that well for a month or so, and im sure this problem has something to do with that, sometimes the blower works as if its okay and other times it doesnt work that well, i have had a look in the battery compartment and there isnt any water there, just a few leaves which i have removed. need to do something fast as the water is not good long term, eventually the car will start to smell stale.
    Dec 2006
    Kent and Guernsey
  1. oil in water
    By christy in forum Archive posts
    Last Post: 06-08-2007, 05:45 PM
  2. Replies: 2
    Last Post: 04-04-2007, 02:20 PM
  3. Build your own DSG box . . .
    By Teutonic_Tamer in forum Chat - Anything with wheels
    Last Post: 07-03-2007, 01:49 PM
  4. Water in car
    By scottishcruiser in forum Passat - Archive Topics
    Last Post: 15-01-2007, 08:09 PM
  5. eos build quality
    By frosty in forum Eos
    Last Post: 11-01-2007, 01:22 PM
