Thread: ABS light - help appreciated
Results 1 to 9 of 9
  1. ABS light - help appreciated
    Sep 2019
    bath
    Hi there,
    My 2010 A3 has had an ABS 'go straight to garage' light flash up. Sent it to my local inde garage and they're saying the ABS control unit needs to be changed for £2k plus. I managed to get their diagnostic codes which I've pasted below. Anyone got any thoughts what I should do next pls?
    Thanks!
    pcosmic
  2. Re: ABS light - help appreciated
    Jun 2016
    Glasgow
    Are the codes hard/do they clear out at all?
  3. Re: ABS light - help appreciated
    Sep 2019
    bath
    Afraid I don't know about that but the dash error messages persist.
  4. Re: ABS light - help appreciated
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    So they read a fault code and concluded its a 2K repair? What diagnosing did they do? I`m not saying it isn`t faulty, but I`d be very wary of that diagnosis. If it transpires the ABS unit requires replacing, I`d send it off for testing/repair at one of a few good companies that repair all manner of automotive electronics. Much cheaper.
    Alan.
    VW T6 150 DSG Camper £££
  5. Re: ABS light - help appreciated
    Sep 2019
    bath
    thanks alan. Do you have names for those companies pls?
  6. Re: ABS light - help appreciated
    131 Post(s)
    1973 Post(s)
    I have given up on all ECU testing and repair companies, even Bosch’s own service from Germany. In almost every case I have been let down with broken promises or estimates that are more than genuine replacement. The A3 ABS unit for 2010, the Mk61, has a reputation for ECU failure and the even big heads like ACTronics can’t do them. That last company cost me two weeks of lost time plus to and fro carriage costs to turn around and say no and make me look an idiot in front of my customer, I am quiet capable of doing that myself without anyone else’s help....
  7. Re: ABS light - help appreciated
    Nov 2008
    20 Post(s)
    Quote Originally Posted by pcosmic View Post
    Never used any of these so cant vouch for them.
    You can search yourself, but 2 I have heard of : ECU Testing
    BBA Reman
    Did you have a diagnosis of the fault or just a code read?
    Alan.
  8. Re: ABS light - help appreciated
    131 Post(s)
    1973 Post(s)
    ECU testing are near me and my stores man used to work for him, I will not use them no matter how many brochures and catalogues they send me. I know BBA Reman very well and have broken bread with the owner Chis, I have been on their forum longer than I have been on here and they have had a couple of success for me but still many failures and incorrect reports on ECU's such as fine when not and vice versa, Mind you even Bosch in Germany have done that to me on a TTRS ECU that I knew full well was faulty but they said wasn't, on the second attempt they agreed as they had "missed" a burnt track and offered me a new unit at £200 more than genuine Audi... If you want to do it once and quickly, buy a new genuine ABS unit. If you PM me your reg I will check what you need and have as the car was probaly built pre 02-11-09 which is the problem area.
  9. Re: ABS light - help appreciated
    131 Post(s)
    1973 Post(s)
    It was built 28/10/2010 and is a 2011 model. It has The ATE Mk60EC ABS system where the complete pump unit is part number 1K0 614 517 DE BEF and costs £1156.61 inc VAT or just the control unit section of the pump is 1K0 907 375 BE at £869.63.
  1. help appreciated
    By maxx16v in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-08-2012, 06:25 PM
  2. Question Any help would be appreciated...
    By pasco in forum Beetle 2000-
    Last Post: 07-05-2009, 06:43 PM
  3. Some help appreciated please
    By Nw001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-03-2008, 06:57 PM
  4. Any help appreciated
    By inmarset in forum Archive posts
    Last Post: 13-12-2007, 08:36 AM
  5. A little help would be much appreciated!
    By PeteChes in forum Archive posts
    Last Post: 26-10-2007, 05:41 PM
