Thread: BRD gear driven balance shaft delete
  1. BRD gear driven balance shaft delete
    Aug 2019
    Manchester
    Has anybody got a write up or any sort of instruction on how to do the balance shaft delete on a BRD engine I’ve got everything I need just need some sort of instruction I can only find the chain driven balance shaft instructions
    I know it’s the same but a gear but I just thought I’d ask
    Any help would be great thank you
    Does anybody know which hole I tap and plug to block of the oil feed that isn’t needed
  2. Re: BRD gear driven balance shaft delete
    May 2012
    Everywhere
    308 Post(s)
    Why delete horizontal twin Lanchester balancer shafts as they do a great job of smoothing out the thumping vertical vibrations of the higher compression of a 4 pot diesel ?
  3. Re: BRD gear driven balance shaft delete
    Aug 2019
    Manchester
    This is the second time it’s broke and it’s ruined 2 turbos now I’ve already changed the hex bar last year, now one of the gears have gone in the balance shaft and staved the turbo of oil, but this time it’s costing me over a grand because I broke the crank sensor seal getting the sump off and after taking the engine out to change it realised it still had the original clutch and flywheel that needed changing aswell so I’ve had to put over a grand in parts in it
    So the delete kit is £200 cheaper then a rebuilt balance shaft
    I’ve also converted it to a single mass flywheel
  4. Re: BRD gear driven balance shaft delete
    May 2012
    Everywhere
    308 Post(s)
    You've just been replacing the 77mm hex bar ?
  1. Question 1.4 tdi balance shaft delete
    By Pimple in forum Polo - Derby - Lupo - Fox
    Last Post: 16-04-2016, 12:12 PM
  2. Balance shaft & hex
    By gareth2689 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-01-2014, 05:31 PM
  3. balance shaft?
    By huyton1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-10-2009, 01:40 PM
