Thread: Flushing Coolant System?
  1. Flushing Coolant System?
    Aug 2019
    england
    Just bought an Audi A4 B6 1.9tdi, Its low on coolant whats the best way to flush the system out and how? help or step by step would be brill thanks guys.
  2. Re: Flushing Coolant System?
    131 Post(s)
    1973 Post(s)
    Just top it up.....
  3. Re: Flushing Coolant System?
    Aug 2019
    england
    Just top it up.....
    Needs flushing coolant looks all moggy orange mucky so needs doing.
  4. Re: Flushing Coolant System?
    131 Post(s)
    1973 Post(s)
    The coolant used, G12, is orange and muddy. The latest spec is purple, G13.
  5. Re: Flushing Coolant System?
    Aug 2019
    england
    Arrr okay , just bought some G12++ am i fine to use this even tho it says G12 heard a few say its fine?
  6. Re: Flushing Coolant System?
    Mar 2016
    Minervois, France
    54 Post(s)
    We've been here before! A3 Coolant and Coolant Hoses
    If it has G11 it should be clear and pale blue, if G12 through G13 it should be clear and pink.
    If it is orange and muddy, it is full of rust, or just maybe a mixture of G11 and a later liquid, and should be flushed thoroughly with clean fresh water.
    The system should be drained and refilled and the radiator and heater matrix back flushed until clean water comes out.
    Detailed instructions for this can be found in a Haynes manual or similar.
    My cooling system contains 7.5 litres, so, after flushing out, for a 40% mixture (2 parts G13 to 3 parts distilled water) giving protection to -24șC, I add 2.5 litres of G13 to the system and top up with distilled water..
    If you bought G12++ this can be mixed with any of the G12 to G13 liquids, but NOT with G11.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 86,533 kms = 54,083 miles on 18/11/2024
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  7. Re: Flushing Coolant System?
    131 Post(s)
    1973 Post(s)
    Yes G12++ is the previous version, the muddy one...
  1. Question Flushing air con system
    By napster87 in forum A8 - S8 - V8
    Last Post: 19-09-2016, 01:07 PM
  2. Flushing foreign object from engine block (coolant side)
    By CaseyJay in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-04-2015, 01:22 PM
  3. flushing heater core and cooling system with citric acid
    By MKultra in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-10-2013, 08:35 AM
  4. flushing cooling system
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-01-2011, 07:31 PM
  5. flushing coolant
    By lone wolf in forum Chat - Anything with wheels
    Last Post: 08-09-2008, 06:46 PM
