Thread: Fabia 1.2 CPG engine change to CPGA
  1. Fabia 1.2 CPG engine change to CPGA
    Aug 2019
    Nuneaton, England
    Have replaced my CPG code engine with CPGA engine.
    Been left with error code... believing excessive fuel is passing through to pre-cat lambda sensor.
    Is this due to possible ECU's calibrations being different, and do I need to replace the new engine's sensor to the old engine's Lambda sensor?
  2. Re: Fabia 1.2 CPG engine change to CPGA
    134 Post(s)
    2009 Post(s)
    There is no CPG, there is a CPGA, CPGB and CGPC where the A and B are the same but the C is a slightly different unit, so what did you car have to start with?
  1. Replies: 0
    Last Post: 15-09-2015, 02:25 PM
  2. mk1 fabia vrs asz engine
    By macmac67 in forum Fabia
    Last Post: 29-12-2010, 10:56 AM
  3. Fabia-Timing Belt Change
    By andypandy in forum Fabia
    Last Post: 04-05-2008, 10:23 PM
  4. Fabia 1.4 8v engine probs
    By czechmate in forum Fabia
    Last Post: 22-04-2008, 01:18 PM
  5. Timing belt change- Skoda Fabia 1.4tdi
    By Howl in forum New Member Introductions
    Last Post: 08-08-2007, 09:40 PM
