Thread: P0299 - 006 - ControlRange Not Reached - Intermittent
Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
  1. Re: P0299 - 006 - ControlRange Not Reached - Intermittent
    #41
    Sheffield, UK
    Good luck, to top it off I needed the head gasket doing as well :-)
    Drives like a new car now though, all the power is back.
    Volkswagen Tiguan 2.0 TDI SE NAV DSG 4motion 195bhp (Stage 1 remap)
    Sheffield, UK
  2. Re: P0299 - 006 - ControlRange Not Reached - Intermittent
    #42
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    " What appears to be a leak of exhaust from the V-band clamp between the turbo and the DPF "
    Get that leak fixed which will be affecting the DPF regens, but not causing low boost.
    If vacuum is all ok, check for leaks in the intake piping between turbo/ intercooler/ inlet.
  3. Re: P0299 - 006 - ControlRange Not Reached - Intermittent
    #43
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by philipharmes View Post
    Moreso due to the fact you'll be breathing Nitrogen Oxide gases which affect heart arrhythmia. I know, first hand.
    The V band should be a dry fit to perfectly clean surfaces, with just metal gasket and no paste or gum used. Paste / gum actually compromises the fit and is bad for the DPF. Having refitted DPFs dozens of times, they do go together perfectly if the clamp is fitted first with DPF supported and loosely bolted down on its mounts to allow a perfectly flat fit. Align properly, snug up the band then tighten the DPF mounting bolts.
  4. Re: P0299 - 006 - ControlRange Not Reached - Intermittent
    #44
    1840 Post(s)
    We have found the clamps do not like being reused.
  5. Re: P0299 - 006 - ControlRange Not Reached - Intermittent
    #45
    Mar 2019
    Thanks for the detailed OST Nick, really really useful. Looks like you spent a fair bit getting it sorted, too!
  1. P0299 - 006 - Control Range Not Reached - Intermittent B6 Passat
    By silversimpson in forum VCDS - Help Requests
    Last Post: 25-07-2019, 08:37 AM
  2. 000665 - Boost Pressure Regulation P0299 - 000 - Control Range Not Reached
    By s1paulj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-08-2017, 08:33 PM
  3. Replies: 0
    Last Post: 27-05-2015, 04:21 PM
  4. Replies: 3
    Last Post: 31-12-2014, 06:09 PM
  5. P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    By Benoticed in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-07-2013, 04:37 PM
