Thread: Amarok oil pressure
  1. Amarok oil pressure
    Aug 2019
    Peterborough
    I own an Amarok 2012 with 140k on it, 100+k of those miles was done by me in the last 3.5 years.
    My problem is the red oil pressure light flashing and beeping usually only after an hour or so of motorway driving when I lift off the gas pedal and start to slow down.
    An oil service seems to cure it for about 2 thousand miles or so but then it returns, intermittently at first but but the closer I get to the next oil change it happens more regular until it occurs every time I lift off the gas.
    I have had this problem checked out a few times and the mechanic can not find any thing wrong.
    Since my ownership its had an EGR cooler and valve, head gasket and oil pump and is serviced every 8-10k.
    The vast majority of my driving is motorway miles and about 15% of it towing a 2.5 tonne trailer, when towing the light comes on even when just cruising unless I leave it in 5th gear and it doesn't come on at all.
    Also on start up the truck sometimes goes in to limp mode and other times it lets me drive as normal but its like the turbos are not working, so I switch it off and on again 2-3 times and all is good again. Both issues have been happening for the last 80 thousand miles or so. So now Im looking at getting shot of it but would rather this issue is sorted first.
    Has anybody heard of this or suffered with it as its slowly driving me nuts
  2. Re: Amarok oil pressure
    Jun 2024
    Ireland
    I’m having an issue where that oil pressure light comes up after about 40 min of driving , Jeep just got serviced 2 months ago and oil pressure sensor was changed out as it was doing it before service , now it’s back again so I’m thinking will it be a faulty wire in the sensor area maybe 🤔
  3. Re: Amarok oil pressure
    114 Post(s)
    1872 Post(s)
    Is it a V6?
    https://youtu.be/w8r2xnITnqA?si=Hy9T6jEbWD5ih-Oy
  4. Re: Amarok oil pressure
    Mar 2010
    Derry ireland
    61 Post(s)
    On most of these there is a oil pressure control valve (a54) can be checked out via ecu
  1. Amarok DPF Light
    By Huntergathering in forum Amarok
    Last Post: 07-01-2019, 11:00 AM
  2. Amarok speaker upgrade
    By Kev.k in forum In Car Entertainment
    Last Post: 12-10-2018, 03:40 PM
  3. Amarok
    By AMAROK in forum The Commercial Range
    Last Post: 16-05-2011, 10:49 AM
  4. amarok wheels
    By AMAROK in forum Wheels and Tyres
    Last Post: 10-03-2011, 11:02 PM
  5. The new Amarok
    By Crasher in forum Chat - Anything with wheels
    Last Post: 05-12-2009, 07:22 PM
