Thread: Help with broken roof antenna replacement
  1. Help with broken roof antenna replacement
    Jun 2019
    Derbyshire
    Hi all
    I have a C5 S6 Avant and the roof antenna was snapped off at the base.
    I couldnt manage to extract just the aerial itself so I purchased a replacement antenna and base on ebay from a 2003 allroad thinking it should fit, as the external part of the antenna looks identical,
    However, when it arrived and I started doing the job, I found that even though the connector matches, the antenna I removed from the car is a different model
    The antenna I removed from the car looks like this:
    The antenna I purchased has a connector that fits the wiring in the car but looks totally different:
    I can't find what these connectors are called anywhere online .. all the antennas I see on ebay seem to have another version of this connector which isn't right
    Does anyone know of an antenna replacement online I can purchase? I found the exact model of antenna but it was used, €80 and came from Germany which is crazy, as the condition will probably be poor as its a 20 year old part. I would rather have a new aftermarket one than an old OEM one
    I guess any antenna I buy will need to have some kind of amp circuitry built in to the base like the one that was removed,
    Thanks in advance for any assistance
  2. Re: Help with broken roof antenna replacement
    Jul 2019
    My anntena is also broken, I also purchased a second hand one which wasn't the correct model and didn't fit. Still looking for another second hand piece, but I am not in a hurry cause the radio works just fine without it. The part should cost 20euro, I paid 5 for the first one
  3. Re: Help with broken roof antenna replacement
    Jun 2019
    Derbyshire
    I just ordered this one from Germany
    Antennenfuß ROKA SNAP für AUDI A3 A4 A6 Sockel Stabantenne Dach Antenne 16V | eBay
    Will report back when it arrives!
    There is an official Audi replacement antenna kit with part number 4B9051505 but its expensive £65... so i'll try this €8 one first!
  4. Re: Help with broken roof antenna replacement
    Jun 2019
    Derbyshire
    After a lot of messing around I can happily confirm this is the correct Antenna for my 2000 Audi S6 - my original broken antenna had an amplifier in the base, and not any additional antenna boosters like some other cars have (possibly later models?)
    Antenne Dachantenne Antennenfuß für Audi A3 S3 A4 S4 A6 S6 A8 Roka Snap Stecker | eBayAntenne Dachantenne Antennenfuß für Audi A3 S3 A4 S4 A6 S6 A8 Roka Snap Stecker | eBay
    As i'm using an aftermarket head unit I also required the following adaptor to power the antenna
    PC5-90 Audi Phantom Amplified ISO to DIN Aerial replacement adaptor antenna | eBay
    Hope this helps someone
  5. Re: Help with broken roof antenna replacement
    Jul 2025
    Ripon, UK
    I'm going to take a bit of a flyer here, as I found your thread through a google search. I have a C5 Allroad, and need a GPS aerial for it. I don't suppose so many years on you still have the one you bought on ebay do you? I'm crossing my fingers....
    Thanks, James.
  1. C5 RS6 avant roof Antenna/aeriel part number
    By michaelk3289 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-09-2016, 11:42 AM
  2. Attention Advice: Beware Aftermarket Roof Antenna / Aerial Bases
    By TSGAB in forum In Car Entertainment
    Last Post: 29-03-2014, 01:45 PM
  3. a4 estate roof antenna amp
    By Google44 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2011, 02:56 PM
  4. roof antenna in the new avant
    By lxbevi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-09-2008, 10:30 PM
  5. VW Roof Aerial/Antenna Base Removal
    By TDi_B5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2007, 08:55 PM
