Thread: Hard coolant pipe removal on Audi tt BAM
  1. Hard coolant pipe removal on Audi tt BAM
    Jun 2015
    GB
    Hi there I needed some advice on removing the hard metal coolant that goes into the block. There a bit where it goes into the block next to the thermostat (where the red line points to, how do you remove it.
    Sent from my SM-G975F using Tapatalk
  2. Re: Hard coolant pipe removal on Audi tt BAM
    134 Post(s)
    2013 Post(s)
    there is a bolt into the head around the corner to the right of the picture, it has a 5mm hex cap head. The pipe is pushed into the block and sealed with an O ring but due to rust can take a LOT of force to get out. I would unbolt the knock sensors and get them out of harms way, their bolts MUST be done to exactly 20Nm.
  3. Re: Hard coolant pipe removal on Audi tt BAM
    Jun 2015
    GB
    Nice 1 Crasher. Thanks for the advice
  1. Intake manifold removal A4 B7 3.0 TDi - coolant pipe in the way
    By nevermindtbc in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-07-2017, 09:24 AM
  2. Air Filter Removal? How Hard can it be?
    By Pauls898 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-03-2016, 06:29 PM
  3. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  4. hard coolant line?
    By mister kloot in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-09-2009, 09:37 PM
