Thread: Idle hiccups TDI
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Idle hiccups TDI
    Jun 2010
    London
    I've had those idle hiccups for a while, seems like they come and go. But now its permanent, after a bit of drive when i stop at the lights i can feel hiccup, it not constant, but could be one every 10 seconds or something, its hard to explain really. No other weird noises, pulls well when on the go, no smoke as well. Pluged in VCDS, no codes at all. Also injectors around 0. There was no changes in fuel, i usually fill up from Costco's station. Fuel filter replaced with genuine around 6 months ago, alternator pulley also not that old, belt isnt jumping. Injector loom replaced couple year ago. Airmass replaced with genuine vw exchange unit.Cant be flywheel, because its a new set fitted. what else could be failing? Thanks in advance
  2. Re: Idle hiccups TDI
    131 Post(s)
    1974 Post(s)
    What is the torsion value?
  3. Re: Idle hiccups TDI
    Jun 2010
    London
  4. Re: Idle hiccups TDI
    131 Post(s)
    1974 Post(s)
    Which year is it?
  5. Re: Idle hiccups TDI
    Jun 2010
    London
    05 tdi. BKC engine
  6. Re: Idle hiccups TDI
    131 Post(s)
    1974 Post(s)
    Glow plug failure crossed my mind but the 05 has active glow plug monitoring. We had a Golf Plus of the same age and engine code do this a few years ago and I could not pin it down. I asked the lady owner to change over to Shell V Power, after two tanks the problem went away and did not return.
  7. Re: Idle hiccups TDI
    Jun 2010
    London
    is liqui moly diesel purge worth a try?
  8. Re: Idle hiccups TDI
    131 Post(s)
    1974 Post(s)
    Possibly, also an oil additive has been shown to reduce stiction (which could match your symptom) in certain designs of injector but as I don’t (haven’t, will not ever) own a Diesel to experiment on.
  9. Re: Idle hiccups TDI
    Jun 2010
    London
    I'll give premium fuel a try and some diesel treatment as well. Nothing to loose anyway
  10. Re: Idle hiccups TDI
    Jun 2010
    London
    Well i've filled up with Shell V-Power 2 full tanks, and it looked like hiccups disappered. So decided to fill up with Costco premium afterwards, and guess what - hiccups came back. Unbelievable. Can't afford to run it on premium all the time...
  1. Please Help Audi A4 B6 has 'hiccups'
    By Chaos2312 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-11-2016, 02:18 PM
  2. black smoke and hiccups
    By jedro750 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-06-2014, 12:07 PM
  3. Please Help Engine Hiccups when stopped at traffic lights?
    By pasta in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-01-2013, 04:25 PM
  4. mk3 golf hiccups. ha!
    By charl88 in forum New Member Introductions
    Last Post: 30-11-2009, 07:05 PM
  5. a4 tdi, limp mode and hiccups
    By jallen69 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2009, 06:52 AM
