Thread: Audi A4 Avant 1.9 Water Leak Passenger Side Footwell
  1. Unhappy Audi A4 Avant 1.9 Water Leak Passenger Side Footwell
    Need some help with a water leak. I recently noticed the front passenger mat was being dripped upon from somewhere under the glovebox. Had a quick look and the water is dripping from a whats best described as a circular bit of foam. lots of help online with the battery tray being a potential source of the problem - I have checked this and it is bone dry.
    Any ideas?
    Water Boy
  2. Re: Audi A4 Avant 1.9 Water Leak Passenger Side Footwell
    That was my thoughts too, the drains under the battery being blocked.
    Is the windscreen sealant faulty perhaps?.
    Do you have a sunroof? Could be drain holes there blocked either, and water could be running down the wiring loom to the dashboard
  3. Unhappy Re: Audi A4 Avant 1.9 Water Leak Passenger Side Footwell
    The drip has appered to stop at last - don't appear to be losing any coolant. I will check and see if the windscreen seal is duff. Forgot to mention when I operate the water for rear wash wipe, it sounds the business but no water!!! Any thoughts oh great ones?
  4. Re: Audi A4 Avant 1.9 Water Leak Passenger Side Footwell
    Could be a blocked water pipe, as it doesn't sound like the pump is faulty.
    Whip off the pipe at the wiper and check does water come out there, and that would rule out a blocked jet, as this caused me grief with my last car. Ffailing that, I would whip off the pipe just out of the pump, and if your getting some water pumping out, then its a blocked pipe.
    After that, all thats left is the filter in the reservoir, and the pump going faulty. hope this helps
  1. WATER in passenger side... Near top of footwell
    By Anzee in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2011, 06:43 PM
  2. major water leak problem A4 Drivers side rear footwell soaking wet
    By steve888 in forum Audi A4 - Archive Topics
    Last Post: 17-01-2008, 10:27 AM
  3. Water leak into front passenger footwell
    By Basil_Brush in forum Touran - Sharan - Caravelle
    Last Post: 17-12-2007, 11:33 PM
  4. Octavia passenger footwell water leak
    By baileyhilldog in forum Octavia
    Last Post: 23-10-2007, 02:53 AM
  5. Passenger Footwell Water Leak...
    By mkpp786 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-06-2007, 02:49 AM
